Delta ASDA-A2 EtherCAT
03 Jan 2021 22:43 #194013 by parisatavakkoli
Delta ASDA-A2 EtherCAT was created by parisatavakkoli
Hi everybody!
I am trying to run a servo drive of part number ASDA-A2-E (with EtherCAT) for an industrial robot.
I use Beckhoff EPC and the servo driver in EhterCAT mode.
How can I make servo driver to memorize EtherCAT parameters like Position Window, Homing Mehtod, Homing Speed, Torque Limit and.... registers? these register's addresses start with 6 and they are related to EtherCAT protocol.
Now I set the parameters but when i shut down the servo and restart it again, all adjusted values are removed!
I am trying to adjust the parameters values through PDOs but any PDO just accept 8 registers and it is not reasonable to set the parameters that they are permanently fixed through EtherCAT PDOs!!
Thanks for your notice!
:kiss:
06 Jan 2021 08:03 #194221 by sqmathlete
Replied by sqmathlete on topic Delta ASDA-A2 EtherCAT
Look in the manual at parameter 3-12.
Dan
