- Thank you received: 9
Servo tuning / debugging help - clarification of context….
5 years 8 months ago #198062
by Jaro
Replied by Jaro on topic Servo tuning / debugging help - clarification of context….
Thank you, Todd.
any value of FF1, whether positive or negative, does not affect the f-error curve. I tried values from -10 to +10.
5 years 8 months ago #198064
by db1981
Replied by db1981 on topic Servo tuning / debugging help - clarification of context….
can you post hal and ini files?
looks like an scaling error or some wrong hal linking
5 years 8 months ago #198066
by bevins
He posted the files in the first post.
Replied by bevins on topic Servo tuning / debugging help - clarification of context….
db1981 wrote: can you post hal and ini files?
- Thank you received: 1480
5 years 8 months ago #198067
Replied by Todd Zuercher on topic Servo tuning / debugging help - clarification of context….
Comment out this line in your hal file for each axis.
net x-vel-cmd => pid.x.command-deriv
5 years 8 months ago #198068
That and you may want to update to a more current version of Linuxcnc.
That problem is caused by a bug in PNCconf that was corrected in later versions of Linuxcnc 2.7.
5 years 8 months ago #198072
by Jaro
now I've 2.7.15 linuxcnc version.
Do you think, upgrade on 2.8 can eliminate this anomaly?
yes I started with PNCconf and then added the necessary functionality.
I 'll try to comment you wrote.tomorow I'll send actual config file.
Time to create page: 0.247 seconds
