I'm having some difficulty understanding how to calibrate the offsets to properly be able to use 5-axis kinematics.
There are six halpins that I believe are related (or that I've seen other people using, especially on the very long switchkins/TCP thread). I'm using an 4th and 5th axis on my mill with the xyac-trt/switchkins kinematics configuration (my machine matches the vismach simulation for xyzac-trt).
setp xyzac-trt-kins.x-offset
setp xyzac-trt-kins.y-offset
setp xyzac-trt-kins.z-offset
setp xyzac-trt-kins.x-rot-point
setp xyzac-trt-kins.y-rot-point
setp xyzac-trt-kins.z-rot-point
The a-axis center of rotation is about 50mm above the top of the x-axis table. My c-axis center of rotation is aligned with the a-axis center of rotation. The top of the c-axis chuck is about 3cm above the a-axis center of rotation.
My question is: what /how do I need to change from these pins in order to calibrate the motion of the machine? I thought that it was only necessary to change the offsets (based on this:
linuxcnc.org/docs/2.8/html/motion/5-axis...inematics_components
), but the motion was totally wrong when in TCP mode.
Thanks,
