5 axis XYZAB
27 Jan 2021 23:46 - 27 Jan 2021 23:46 #196897 by hodianmkr
5 axis XYZAB was created by hodianmkr
Hi All -
I just recently joined these forums in hopes of requesting a bit of help. I've built a 5axis machine and hoping to do a bit of continuous 5axis motion with it. It's a rotary head ( B ) and rotary chuck (A). Essentially, I am cutting long-thin boards which needs support at both ends (hence why a C axis configuration won't meet my needs)
I recognize this is probably a bit unusual as I see support for XYZBC and XYZAC built-in, yet my searches have rendered nothing for my BA configuration. (I found one that matches dynamotion controller yet I was hoping to stick w/ linuxcnc)
My trig is pretty weak so I am wondering if one of you have created a Kinematics configuration for XYZAB supporting TCP?
If so, would you mind sharing?
Thanks you
Last edit: 27 Jan 2021 23:46 by hodianmkr. Reason: fixed emoji
28 Jan 2021 10:41 #196962 by Todd Zuercher
Replied by Todd Zuercher on topic 5 axis XYZAB
I don't think an XYZAB 5 axis machine would be that uncommon, and the configuration would certainly be supported in Linuxcnc.
But I have no experience with a 5 axis machine, either configuring it or even using one. So I won' be much help for you there. There are a number of threads on the forum discussing the problems with setting setting up and using TCP on a 5 axis machine with Linuxcnc. Sounds like you have a lot of reading to do.
28 Jan 2021 12:47 #196983 by hodianmkr
Replied by hodianmkr on topic 5 axis XYZAB
I've done just that, in these forums and others; hence the reason for my post. No luck, yet.
28 Jan 2021 18:22 #197010 by andypugh
Replied by andypugh on topic 5 axis XYZAB
Did you find
linuxcnc.org/docs/2.8/html/motion/5-axis-kinematics.html ?
I sort-of have an XYZAB machine, but currently I only have extremely rudimentary kinematics and haven't tried TCP working.
I think if I was trying to set it up I would try combining the A stuff from:
github.com/LinuxCNC/linuxcnc/blob/master...ics/xyzac-trt-kins.c
and the B stuff from:
github.com/LinuxCNC/linuxcnc/blob/master...ics/xyzbc-trt-kins.c
And then keep fiddling in a sim config until it looked close.
28 Jan 2021 19:41 #197020 by hodianmkr
Did you find
Yep, I've been through those docs and that's exactly what I'm doing; merging BC and AC. I just went through a test run of using vismatch + simulation to do this (lest I destroy my machine).
Also looking at this: www.dynomotion.com/forum/viewtopic.php?t=731 for the requirements.
So next I'll build the stl models then start hacking up the AC/BC examples
Anecdotally - I've had my eye on linuxcnc for many years and this is the first I've delved into vismatch, etc. I think I'm in love :blush: I can get all of this simulated without sitting my cold shopspace for early test runs
Time to create page: 0.078 seconds
