How to change PWM Frequency?
  • roland
  • roland's Avatar Topic Author
  • Premium Member
  • Premium Member
28 Jan 2021 03:21 #196911 by roland
How to change PWM Frequency? was created by roland
i need to change the frequency of the pwmgen during runtime.
Unfortunately this does not work. I cannot link hm2_7i92.0.pwmgen.pwm_frequency to a signal.
For that, pwm_frequency would have to be a pin and not a parameter.
How can I change the pwm frequency with a singal?
Roland
28 Jan 2021 10:59 #196965 by PCW
Replied by PCW on topic How to change PWM Frequency?
Yes, HM2 PWM frequency is a parameter not a pin so it cannot be linked to a signal
If its just changed occasionally you can use a script with setp
What is the application? maybe PWM is not the best solution.
  • roland
  • Premium Member
  • Premium Member
28 Jan 2021 11:42 #196978 by roland
Replied by roland on topic How to change PWM Frequency?
A solenoid valve regulates the flow. The valve is opened 10 times per second for a short time.
So far I do this with pwmgen.
PWM Frequency = 10 Hz
Value 0,062 results in a pulse width of 6.2 ms
Value 0.014 results in a pulse width of 1.4 ms
Up to here everything is fine.
At Value < 0.014 the pulse width becomes < 1.4 ms.
But a smaller pulse width than 1.4 ms cannot switch the valve.
To be able to work with value < 0.014, the frequency must be reduced here.
28 Jan 2021 12:02 - 28 Jan 2021 12:05 #196980 by PCW
At that low a frequency you are probably better of using software PWM
perhaps siggen and oneshot, or it may be that the software PWM
will work with pwmgen.0.dither-pwm set true (and a 500 Hz thread so
the minimum pulse width is never less than 2 ms)
Another option is using the rcpwmgen (made for RC servos) this has
a rate pin and a .01 to 1KHz PWM rate
man hostmot2
Last edit: 28 Jan 2021 12:05 by PCW.
  • roland
  • Premium Member
  • Premium Member
28 Jan 2021 13:06 #196984 by roland
oneshot and siggen I have tested. That works. The problem is that the pulse width is always a multiple of 1 ms. This is too inaccurate.
Is a new bit file necessary for rcpwmgen?
Attached is my current .vhd file. What must be changed here?
File Name: PIN_7I76_7....vhd.txt
File Size:10 KB
28 Jan 2021 13:24 #196985 by PCW
Basically just the module and the pin name, but I just realized a limitation of the rcpwmgen
that may make it an issue, the maximum pulse width is ~10 ms, what is you maximum pulse width?
  • roland
  • Premium Member
  • Premium Member
28 Jan 2021 13:31 #196988 by roland
maximum pulse width is 6.2 ms
28 Jan 2021 13:47 #196990 by PCW
OK then it should work,
The new module line would be:
(RCPWMTag, x"00", ClockLowTag, x"01", RCPWMWidthAddr&PadT, RCPWMNumRegs, x"00", RCPWMMPBitMask),
and the new pin line would be:
IOPortTag & x"00" & RCPWMTag & RCPWMOutPin,
  • roland
  • Premium Member
  • Premium Member
28 Jan 2021 14:52 #196992 by roland
I was not able to generate the bitfile.
I get this error message:
ERROR:HDLCompiler:69 - "/home/ise/xilinx/7i92/PIN_7I76_7I85SD_RCPWM_SERVO_34.vhd" Line 82: <rcpwmtag> is not declared.
ERROR:HDLCompiler:69 - "/home/ise/xilinx/7i92/PIN_7I76_7I85SD_RCPWM_SERVO_34.vhd" Line 120: <rcpwmtag> is not declared.
ERROR:HDLCompiler:854 - "/home/ise/xilinx/7i92/PIN_7I76_7I85SD_RCPWM_SERVO_34.vhd" Line 72: Unit <pin_7i76_7i85sd_rcpwm_servo_34> ignored due to previous errors.
Can you support me a bit more?
File Size:10 KB
28 Jan 2021 15:57 #196995 by PCW
Sounds like you don't have the latest source
constant RCPWMTag : std_logic_vector(7 downto 0) := x"2C";
constant RCPWMOutPin : std_logic_vector(7 downto 0) := x"81";
are in the current IDROMConst.vhd
The following user(s) said Thank You: roland
Time to create page: 0.149 seconds
