Interpolation error
  • Ingo
  • Ingo's Avatar Topic Author
  • Premium Member
  • Premium Member
06 Feb 2021 10:20 #197841 by Ingo
Interpolation error was created by Ingo
Hello Guys, I'm working on a retroffiting with linuxcnc version 2.9 and 7i76E. Drives and servo motor (Chinese), the machine is making contours all perfect dimensions, but I'm pretty crazy because the interpolation is vibrating (leaving the axle just after reversing the axes) in the 4 corners, very symmetrical, only more on the Y axis (+ and -). I sent the images of the piece to see and understand better. The last image in calibration, where I changed the PID values ​​(without positive results), I changed the FF’s (I didn’t accept the change, as soon as it changed, there was an error on the machine), I changed all without good results. The step_scale was the first one that I adjusted the dimensional part and it was great. Ah, I also used the codes G’s, G61, G61.1. (the machine was shaking all over), I used the G64 P0.01, G64 Q0.01 (it didn't get better or worse ...). Guys I'm very lost if someone can show a light thank you very much.
06 Feb 2021 11:00 #197847 by PCW
Replied by PCW on topic Interpolation error
Can you post your hal and ini files?
06 Feb 2021 11:05 #197848 by chris@cnc
Replied by chris@cnc on topic Interpolation error
And what Kind of Servos do you use ? And your NC Programm is you circle written like this example or small Steps?
G2X0.000Y-40.000I-40.000J0.000
G2X-40.000Y0.000I0.000J40.000
G2X0.000Y40.000I40.000J0.000
06 Feb 2021 12:08 #197854 by scotth
Replied by scotth on topic Interpolation error
Looks like backlash. They are worse at the reversal points.
  • Ingo
  • Premium Member
  • Premium Member
06 Feb 2021 13:03 #197863 by Ingo
Replied by Ingo on topic Interpolation error
Follow the hal and ini files
  • Ingo
  • Premium Member
  • Premium Member
06 Feb 2021 13:06 #197864 by Ingo
I am using Cimatron programming and I can only do it with G1 point to point. I tried to make a manual program in G2 and G3 as your example no longer ran.
  • Ingo
  • Premium Member
  • Premium Member
06 Feb 2021 13:08 #197865 by Ingo
Hi Scotth, do you know where to do this?
06 Feb 2021 13:14 - 06 Feb 2021 13:15 #197866 by PCW
OK the hal/ini files look OK so I would expect the error is not in step generation
Last edit: 06 Feb 2021 13:15 by PCW.
06 Feb 2021 13:39 #197868 by chris@cnc
i guess pretty sure it's a tuning problem. But without to know which hardware did you use its hard to say, a useful answer. First step could be try to set the P value to 5 or 10 and see what happens. Another idea would be put a pencil in spindle and write the circle on paper. So you can see wath do machine without load.
this is example for 100mm circle and center is zero
G0X0.000Y50.000
G0Z5.000
G1Z0.000
G2X0.000Y50.000I0.000J-50.000
G0...
06 Feb 2021 13:41 #197869 by scotth
Look at this it wioo show you how he was testing.
forum.linuxcnc.org/49-basic-configuratio...etup?start=40#126232
Time to create page: 0.103 seconds
