work with probe error
- sibelius
- Visitor
28 Feb 2021 05:53 #200393
by sibelius
work with probe error was created by sibelius
Good evening everybody
I have tried to follow this link forum.linuxcnc.org/49-basic-configuration/29187-work-with-probe to try to figure out how install the interface.
I attached also the error and my ini and hal file that I had modified.
I am wondering if i really need this Ferrari car when I cannot even drive a bicycle; all i want to do is:
1) insert Tool_1 in my 27$ spindle
2) press a button and send Tool_2 to P1(x1,y1,z1) where can be measured (P1 is fix somewhere on the table)
3) make the tip of Tool_1 G54 in P2(x2,y2,z2) (origin of my piece of wood)
4) mill my piece of wood
If my gcode does not have M6 inside than everything is fine but, if my gcode find M6 along the way what I'd like to do is:
1) stop the movement in P3(x3,y3,z3) ----corresponding to the P at the gcode line before M6
2) manually turn off my spindle
3) send the spindle to a P3(x3,y3,z3) where i want to manually remove Tool_1 and insert Tool_2
4) press a button and send Tool_2 to P1(x1,y1,z1) where can be measured and the dimension compered with Tool_1
5) press a button and send back my 27$ friend to my piece of wood and hopefully the tip of Tool_2 would be "exactly" to P3(x3,y3,z3)
6) turn on manually my spindle
7) finish milling my piece of wood
Thanks in advance for any help.
V.
V.
- newbynobi
- Thank you received: 394
28 Feb 2021 15:48 #200467
by newbynobi
Replied by newbynobi on topic work with probe error
In your INI file you try to load maccina_3.hal but you added maccina_4.hal.
Ther error mentions explicit, that maccina3. Hal is not found.
Typical copy and past error???
Norbert
Norbert
- sibelius
- Visitor
28 Feb 2021 23:14 #200506
by sibelius
Replied by sibelius on topic work with probe error
Hello
Thanks for your answer, I will have a go.
Regards,
V.
Regards,
V.
Time to create page: 0.093 seconds
