Multiple Axis' off of a single servo Amplifer?
- deerefanatic
- Topic Author
5 years 7 months ago #202928
by deerefanatic
Multiple Axis' off of a single servo Amplifer? was created by deerefanatic
Hello,
I'm beginning to do research on my Wotan Horizontal Boring mill retrofit (build thread here: forum.linuxcnc.org/30-cnc-machines/41951...-1-linuxcnc-retrofit ) and had a question about a unique situation..
The boring mill was retrofit back in the 90's to a Dynapath control. The mill has X/Y/Z axis using Allen Bradley 1388 servo amps and Brushed DC Servos. The mill also has a W axis (the spindle quill) and a B axis rotary table. But instead of having separate servo amps, they wired the machine to have a single servo amp, an then contactors to switch the power between the motors and also switch the tach generators coming into the amp. The Dynapath was wired in with a single W/B axis Enable output on it's plc, and then separate W and B enable outputs that would select which axis would be driven.
My guess is that the reason this was done is that quill movements are typically positional type movements or used for drilling/tapping cycles, thus there would never be a need for simultaneous movement on these two axis'
The real question, is this possible for LinuxCNC to control? there are Linear scales on the machine, so I think they kept track of the positioning of these two axis by referencing those.
- scotth
- Thank you received: 62
5 years 7 months ago #202973
by scotth
Replied by scotth on topic Multiple Axis' off of a single servo Amplifer?
On a Devlieg we always used individual drives. For a true XYZWB configuration.
Geometrically the problem was always bar droop. You are looking at the cost of one drive and far fewer problems.
5 years 7 months ago #203004
Yes. In fact it helps that one of the axes is a rotary, as LinuxCNC has built-in handling of brakes for rotary axes (I keep meaning to remove the limitation to rotary axes).
If you configure the changeover to be operated by the B axis "brake" (even if it isn't a brake...) so that W is active when B is stopped then it should all be automatic.
Look for "locking_indexer" on this page: linuxcnc.org/docs/2.8/html/config/ini-config.html
Replied by andypugh on topic Multiple Axis' off of a single servo Amplifer?
deerefanatic wrote: The real question, is this possible for LinuxCNC to control?
- deerefanatic
- Topic Author
5 years 7 months ago #203264
by deerefanatic
Replied by deerefanatic on topic Multiple Axis' off of a single servo Amplifer?
Well, that is great news, as that will save me some significant money vs buying another servo drive.. Even these Old AB servos on eBay are still kinda spendy.
Time to create page: 0.209 seconds
