- Configuring LinuxCNC
- Advanced Configuration
- G1 Moves and Arbitrary Python within single custom G-code/M-code Help
- jiso
22 Mar 2021 16:36 #203297
by jiso
G1 Moves and Arbitrary Python within single custom G-code/M-code Help was created by jiso
Problem
I would like to be able to define a custom G-code or M-code able to execute arbitrary Python code between G1 moves, similar to the example below. The reason is because information about how to prepare the tool or the number of moves required is only available during execution of the ngc file.
Things I've Tried
1. Everything Together
Placing everything in the same function results in the Python executing where it is placed, but the G-code executing after the function handler returns (i.e. in the order shown below). I think this is due to read-ahead (linuxcnc.org/docs/devel/html/remap/remap...euing_and_read_ahead).
2. Separating Python into its own M-code
I also tried separating the tool prep into its own M-code and then executing that from the main remap function, but was unable to get it to work. This linked topic suggests that custom remapped functions cannot be executed from remapped functions (www.forum.linuxcnc.org/10-advanced-confi...rom-a-remapped-cycle).
3. Yield read-ahead
The last major thing I tried was to stop read-ahead with yield INTERP_EXECUTE_FINISH. As per testing and the documentation, it does not seem possible to execute commands with the interpreter following such a yield (linuxcnc.org/docs/devel/html/remap/remap...ntions_ngc_to_python).
4. linuxcnc module
I've done some testing with linuxcnc.command.mdi in remaps, but I haven't gotten it to work yet, and it's not something I've examined closely.
Is there a way for this type of sequential operation to occur with a single G-code/M-code?
""" remap.py """
def m200(self, **words):
self.execute("G1 X100 Y0")
prepare_tool_for_move()
self.execute("G1 X100 Y100")
# and so on...Things I've Tried
""" remap.py """
self.execute("G1 X100 Y0") # 3
prepare_tool_for_move() # 1
self.execute("G1 X100 Y100") # 4
prepare_tool_for_move() # 22. Separating Python into its own M-code
""" remap.py """
def m300(self, **words):
self.execute("M300")
self.execute("M300")3. Yield read-ahead
""" remap.py """
""" interpreter does not execute commands beyond here """
prepare_tool_for_move()4. linuxcnc module
- Thank you received: 4658
22 Mar 2021 17:47 #203313
Replied by andypugh on topic G1 Moves and Arbitrary Python within single custom G-code/M-code Help
In the Python interface there is a wait_complete() call.
linuxcnc.org/docs/2.8/html/config/python-interface.html
I don't know what that is equivalent to in the remap environment (which is different)
github.com/LinuxCNC/linuxcnc/blob/65f426...s/emcmodule.cc#L1375
Time to create page: 0.199 seconds
