Homing - Single Axis Dual Motors - Racking Problem
- Thank you received: 4658
06 Apr 2021 17:55 #205209
Replied by andypugh on topic Homing - Single Axis Dual Motors - Racking Problem
Yes. It just means that the first axis to hit the switch will latch slowly towards the second axis.
- AcBCDN
06 Apr 2021 20:34 - 06 Apr 2021 20:36 #205219
by AcBCDN
Ok, this .ini file works. I don't understand.
Joint 1 is HOME_LATCH_VEL = -0.625 and Joint 4 is HOME_LATCH_VEL = 0.625
Andy
Replied by AcBCDN on topic Homing - Single Axis Dual Motors - Racking Problem
The distance between joint 1 trigger and joint 4 trigger is less than .5mm. I manually stepped want watch each trigger activate.
Negative on each? (I assume)
Andy
Last edit: 06 Apr 2021 20:36 by AcBCDN. Reason: Scratch that. I forgot to edit the limit switches (face palm)
07 Apr 2021 03:25 #205237
That doesn't really make sense.
Is there any chance that the two sides of the gantry have their home switches crossed?
The following user(s) said Thank You: AcBCDN
- AcBCDN
07 Apr 2021 08:45 #205254
by AcBCDN
Its is my error.
I have two .hal files for the limit switches. One for using a single limit switch on joint 1 and one for testing limit switches on Joint 1 and Joint 4. I did not use the correct file.
My mistake. Sorry about that.
- Thank you received: 4155
07 Apr 2021 13:19 #205275
Whenever I've seen the gantry rack on homing, its ALWAYS been due to a wiring error like this.
Replied by rodw on topic Homing - Single Axis Dual Motors - Racking Problem
- AcBCDN
07 Apr 2021 13:49 #205278
by AcBCDN
Yup it was not the wiring, it was the guy (me) who check the pin assignment 3 times and got it wrong three times.
After being reassured by everyone here multiple times the config was ok I knew it was something I was missing.
I am happy to have it working as expected and appreciate the assistance.
Time to create page: 0.127 seconds
