Error EMC2
17 Sep 2010 08:49 #4226 by marcguenel
Error EMC2 was created by marcguenel
I have instaled Lucid Linx with EMC2.
Lucid work find but when i want to run EMC2 I have the logo and then this error message :( :
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.3
Machine configuration directory is '/home/marco/emc2/configs/sim'
Machine configuration file is 'axis.ini'
INIFILE=/home/marco/emc2/configs/sim/axis.ini
PARAMETER_FILE=sim.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Realtime system did not load
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=1329
Cleanup done
Debug file information:
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
1329
PID TTY STAT TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
Unloading hal components
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003fff0000 (usable)
[ 0.000000] BIOS-e820: 000000003fff0000 - 000000003fff8000 (ACPI data)
[ 0.000000] BIOS-e820: 000000003fff8000 - 0000000040000000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffee0000 - 00000000fff00000 (reserved)
[ 0.000000] BIOS-e820: 00000000fffc0000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.3 present.
[ 0.000000] AMI BIOS detected: BIOS may corrupt low RAM, working around it.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0x3fff0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-DFFFF write-protect
[ 0.000000] E0000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 base 0D0000000 mask FFC000000 write-combining
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] Scanning 0 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000010000 (reserved)
[ 0.000000] modified: 0000000000010000 - 000000000009fc00 (usable)
[ 0.000000] modified: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000003fff0000 (usable)
[ 0.000000] modified: 000000003fff0000 - 000000003fff8000 (ACPI data)
[ 0.000000] modified: 000000003fff8000 - 0000000040000000 (ACPI NVS)
[ 0.000000] modified: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] modified: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] modified: 00000000ffee0000 - 00000000fff00000 (reserved)
[ 0.000000] modified: 00000000fffc0000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 377fe000 @ 10000-15000
[ 0.000000] RAMDISK: 2f3b4000 - 3003348b
[ 0.000000] ACPI: RSDP 000fa340 00014 (v00 AMI )
[ 0.000000] ACPI: RSDT 3fff0000 00028 (v01 AMIINT SiS735XX 00001000 MSFT 0100000B)
[ 0.000000] ACPI: FACP 3fff0030 00074 (v01 AMIINT SiS735XX 00001000 MSFT 0100000B)
[ 0.000000] ACPI: DSDT 3fff0100 03332 (v01 SiS 735 00000100 MSFT 0100000D)
[ 0.000000] ACPI: FACS 3fff8000 00040
[ 0.000000] 135MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] node 0 low ram: 00000000 - 377fe000
[ 0.000000] node 0 bootmap 00011000 - 00017f00
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 00377fe000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [002f3b4000 - 003003348b] RAMDISK ==> [002f3b4000 - 003003348b]
[ 0.000000] #5 [000009fc00 - 0000100000] BIOS reserved ==> [000009fc00 - 0000100000]
[ 0.000000] #6 [00008b1000 - 00008b4294] BRK ==> [00008b1000 - 00008b4294]
[ 0.000000] #7 [0000010000 - 0000011000] PGTABLE ==> [0000010000 - 0000011000]
[ 0.000000] #8 [0000011000 - 0000018000] BOOTMAP ==> [0000011000 - 0000018000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0003fff0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0003fff0
[ 0.000000] On node 0 totalpages: 262015
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 272 pages used for memmap
[ 0.000000] HighMem zone: 34530 pages, LIFO batch:7
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] Allocating PCI resources starting at 40000000 (gap: 40000000:bec00000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c1c00000 s74936 r0 d23368 u4194304
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259967
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=427307ce-0db6-46f1-9f7e-d1af038e5452 ro quiet splash
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 5242240 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0003fff0)
[ 0.000000] Memory: 1012620k/1048512k available (4539k kernel code, 34924k reserved, 1928k data, 620k init, 139208k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1194.792 MHz processor.
[ 0.008014] Calibrating delay loop (skipped), value calculated using timer frequency.. 2389.58 BogoMIPS (lpj=4779168)
[ 0.008072] Security Framework initialized
[ 0.008142] AppArmor: AppArmor initialized
[ 0.008161] Mount-cache hash table entries: 512
[ 0.012309] Initializing cgroup subsys ns
[ 0.012324] Initializing cgroup subsys cpuacct
[ 0.012333] Initializing cgroup subsys memory
[ 0.012354] Initializing cgroup subsys devices
[ 0.012360] Initializing cgroup subsys freezer
[ 0.012365] Initializing cgroup subsys net_cls
[ 0.012407] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 0.012413] CPU: L2 Cache: 64K (64 bytes/line)
[ 0.012423] mce: CPU supports 4 MCE banks
[ 0.012474] Performance Events: AMD PMU driver.
[ 0.012489] ... version: 0
[ 0.012493] ... bit width: 48
[ 0.012497] ... generic registers: 4
[ 0.012501] ... value mask: 0000ffffffffffff
[ 0.012505] ... max period: 00007fffffffffff
[ 0.012509] ... fixed-purpose events: 0
[ 0.012513] ... event mask: 000000000000000f
[ 0.012523] Checking 'hlt' instruction... OK.
[ 0.029120] SMP alternatives: switching to UP code
[ 0.039276] Freeing SMP alternatives: 31k freed
[ 0.039365] ACPI: Core revision 20090903
[ 0.049046] ACPI: setting ELCR to 0200 (from 1820)
[ 0.052032] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.052050] ftrace: allocating 21003 entries in 42 pages
[ 0.065734] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.065746] weird, boot CPU (#0) not listed by the BIOS.
[ 0.065750] SMP motherboard not detected.
[ 0.065757] Local APIC not detected. Using dummy APIC emulation.
[ 0.065761] SMP disabled
[ 0.066304] Brought up 1 CPUs
[ 0.066313] Total of 1 processors activated (2389.58 BogoMIPS).
[ 0.066573] CPU0 attaching NULL sched-domain.
[ 0.066994] devtmpfs: initialized
[ 0.067762] regulator: core version 0.5
[ 0.067918] NET: Registered protocol family 16
[ 0.068279] EISA bus registered
[ 0.068309] ACPI: bus type pci registered
[ 0.070152] PCI: PCI BIOS revision 2.10 entry at 0xfdb01, last bus=1
[ 0.070158] PCI: Using configuration type 1 for base access
[ 0.071956] bio: create slab <bio-0> at 0
[ 0.073002] ACPI: EC: Look up EC in DSDT
[ 0.081476] ACPI: Interpreter enabled
[ 0.081489] ACPI: (supports S0 S5)
[ 0.081513] ACPI: Using PIC for interrupt routing
[ 0.089822] ACPI: Power Resource [URP1] (off)
[ 0.089882] ACPI: Power Resource [URP2] (off)
[ 0.089937] ACPI: Power Resource [FDDP] (off)
[ 0.089990] ACPI: Power Resource [LPTP] (off)
[ 0.090203] ACPI: No dock devices found.
[ 0.091010] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.091135] pci 0000:00:00.0: reg 10 32bit mmio: [0xd0000000-0xd3ffffff]
[ 0.091302] pci 0000:00:02.0: Enabling SiS 96x SMBus
[ 0.091357] pci 0000:00:02.1: reg 20 io port: [0xc00-0xc1f]
[ 0.091400] pci 0000:00:02.2: reg 10 32bit mmio: [0xcfffe000-0xcfffefff]
[ 0.091461] pci 0000:00:02.3: reg 10 32bit mmio: [0xcffff000-0xcfffffff]
[ 0.091542] pci 0000:00:02.5: reg 20 io port: [0xff00-0xff0f]
[ 0.091600] pci 0000:00:02.7: reg 10 io port: [0xdc00-0xdcff]
[ 0.091610] pci 0000:00:02.7: reg 14 io port: [0xd800-0xd83f]
[ 0.091660] pci 0000:00:02.7: PME# supported from D3hot D3cold
[ 0.091668] pci 0000:00:02.7: PME# disabled
[ 0.091712] pci 0000:00:03.0: reg 10 io port: [0xd400-0xd4ff]
[ 0.091723] pci 0000:00:03.0: reg 14 32bit mmio: [0xcfffd000-0xcfffdfff]
[ 0.091753] pci 0000:00:03.0: reg 30 32bit mmio pref: [0xcffc0000-0xcffdffff]
[ 0.091776] pci 0000:00:03.0: supports D1 D2
[ 0.091781] pci 0000:00:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.091788] pci 0000:00:03.0: PME# disabled
[ 0.091838] pci 0000:00:0b.0: reg 10 32bit mmio: [0xcfff9000-0xcfff9fff]
[ 0.091889] pci 0000:00:0b.0: PME# supported from D0 D1 D3hot D3cold
[ 0.091896] pci 0000:00:0b.0: PME# disabled
[ 0.091935] pci 0000:00:0b.1: reg 10 32bit mmio: [0xcfffa000-0xcfffafff]
[ 0.092047] pci 0000:00:0b.1: PME# supported from D0 D1 D3hot D3cold
[ 0.092054] pci 0000:00:0b.1: PME# disabled
[ 0.092095] pci 0000:00:0b.2: reg 10 32bit mmio: [0xcfffb000-0xcfffbfff]
[ 0.092146] pci 0000:00:0b.2: PME# supported from D0 D1 D3hot D3cold
[ 0.092153] pci 0000:00:0b.2: PME# disabled
[ 0.092199] pci 0000:00:0b.3: reg 10 32bit mmio: [0xcfffcf00-0xcfffcfff]
[ 0.092254] pci 0000:00:0b.3: PME# supported from D0 D3hot D3cold
[ 0.092261] pci 0000:00:0b.3: PME# disabled
[ 0.092310] pci 0000:00:0d.0: reg 10 32bit mmio: [0xcffe0000-0xcffeffff]
[ 0.092360] pci 0000:00:0d.0: PME# supported from D0 D3hot
[ 0.092367] pci 0000:00:0d.0: PME# disabled
[ 0.092445] pci 0000:01:00.0: reg 10 32bit mmio: [0xce000000-0xceffffff]
[ 0.092455] pci 0000:01:00.0: reg 14 32bit mmio pref: [0xc0000000-0xc7ffffff]
[ 0.092482] pci 0000:01:00.0: reg 30 32bit mmio pref: [0xcfef0000-0xcfefffff]
[ 0.092556] pci 0000:00:01.0: bridge 32bit mmio: [0xcde00000-0xcfefffff]
[ 0.092564] pci 0000:00:01.0: bridge 32bit mmio pref: [0xbdc00000-0xcdcfffff]
[ 0.092577] pci_bus 0000:00: on NUMA node 0
[ 0.092590] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.095937] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 7 10 11 12 14 15)
[ 0.096208] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 7 10 11 12 14 15)
[ 0.096402] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 10 *11 12 14 15)
[ 0.096593] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 7 10 11 12 14 15)
[ 0.096782] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.096972] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.097162] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 10 *11 12 14 15)
[ 0.097350] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 11 *12 14 15)
[ 0.097641] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.097648] vgaarb: loaded
[ 0.097957] SCSI subsystem initialized
[ 0.098191] libata version 3.00 loaded.
[ 0.098450] usbcore: registered new interface driver usbfs
[ 0.098477] usbcore: registered new interface driver hub
[ 0.098553] usbcore: registered new device driver usb
[ 0.098925] ACPI: WMI: Mapper loaded
[ 0.098931] PCI: Using ACPI for IRQ routing
[ 0.099272] NetLabel: Initializing
[ 0.099278] NetLabel: domain hash size = 128
[ 0.099281] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.099313] NetLabel: unlabeled traffic allowed by default
[ 0.099415] Switching to clocksource tsc
[ 0.100897] AppArmor: AppArmor Filesystem Enabled
[ 0.100949] pnp: PnP ACPI init
[ 0.101002] ACPI: bus type pnp registered
[ 0.107142] pnp: PnP ACPI: found 12 devices
[ 0.107150] ACPI: ACPI bus type pnp unregistered
[ 0.107161] PnPBIOS: Disabled by ACPI PNP
[ 0.142164] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.142172] pci 0000:00:01.0: IO window: disabled
[ 0.142183] pci 0000:00:01.0: MEM window: 0xcde00000-0xcfefffff
[ 0.142191] pci 0000:00:01.0: PREFETCH window: 0xbdc00000-0xcdcfffff
[ 0.142218] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.142224] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.142231] pci_bus 0000:01: resource 1 mem: [0xcde00000-0xcfefffff]
[ 0.142236] pci_bus 0000:01: resource 2 pref mem [0xbdc00000-0xcdcfffff]
[ 0.142325] NET: Registered protocol family 2
[ 0.142536] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.143465] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.147409] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.149314] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.149322] TCP reno registered
[ 0.149581] NET: Registered protocol family 1
[ 0.149773] pci 0000:01:00.0: Boot video device
[ 0.150290] Scanning for low memory corruption every 60 seconds
[ 0.150530] audit: initializing netlink socket (disabled)
[ 0.150567] type=2000 audit(1284712688.148:1): initialized
[ 0.164761] Trying to unpack rootfs image as initramfs...
[ 0.180945] highmem bounce pool size: 64 pages
[ 0.180963] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.188853] VFS: Disk quotas dquot_6.5.2
[ 0.189093] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.190461] fuse init (API version 7.13)
[ 0.190683] msgmni has been set to 1706
[ 0.196847] alg: No test for stdrng (krng)
[ 0.197101] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.197110] io scheduler noop registered
[ 0.197115] io scheduler anticipatory registered
[ 0.197119] io scheduler deadline registered
[ 0.197217] io scheduler cfq registered (default)
[ 0.197454] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.197522] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.197733] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 0.197753] ACPI: Sleep Button [SLPB]
[ 0.197862] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.197868] ACPI: Power Button [PWRF]
[ 0.200618] isapnp: Scanning for PnP cards...
[ 0.206965] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.207146] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.207348] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.207867] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.208089] 00:08: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.208756] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
[ 0.208767] PCI: setting IRQ 11 as level-triggered
[ 0.208776] serial 0000:00:0d.0: PCI INT A -> Link[LNKC] -> GSI 11 (level, low) -> IRQ 11
[ 0.208793] serial 0000:00:0d.0: PCI INT A disabled
[ 0.211051] brd: module loaded
[ 0.212132] loop: module loaded
[ 0.260359] input: Macintosh mouse button emulation as /devices/virtual/input/input2
[ 0.260771] pata_sis 0000:00:02.5: version 0.5.2
[ 0.265024] scsi0 : pata_sis
[ 0.265476] scsi1 : pata_sis
[ 0.266870] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xff00 irq 14
[ 0.266878] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xff08 irq 15
[ 0.267716] Fixed MDIO Bus: probed
[ 0.267791] PPP generic driver version 2.4.2
[ 0.267957] tun: Universal TUN/TAP device driver, 1.6
[ 0.267962] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.268227] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.269109] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 5
[ 0.269120] PCI: setting IRQ 5 as level-triggered
[ 0.269129] ehci_hcd 0000:00:0b.3: PCI INT A -> Link[LNKB] -> GSI 5 (level, low) -> IRQ 5
[ 0.269175] ehci_hcd 0000:00:0b.3: EHCI Host Controller
[ 0.269395] ehci_hcd 0000:00:0b.3: new USB bus registered, assigned bus number 1
[ 0.269466] ehci_hcd 0000:00:0b.3: debug port 1
[ 0.292561] ehci_hcd 0000:00:0b.3: irq 5, io mem 0xcfffcf00
[ 0.304902] ehci_hcd 0000:00:0b.3: USB 2.0 started, EHCI 1.00
[ 0.305243] usb usb1: configuration #1 chosen from 1 choice
[ 0.305337] hub 1-0:1.0: USB hub found
[ 0.305370] hub 1-0:1.0: 6 ports detected
[ 0.305526] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.305948] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 5
[ 0.305960] ohci_hcd 0000:00:02.2: PCI INT D -> Link[LNKD] -> GSI 5 (level, low) -> IRQ 5
[ 0.306006] ohci_hcd 0000:00:02.2: OHCI Host Controller
[ 0.306180] ohci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 2
[ 0.306234] ohci_hcd 0000:00:02.2: irq 5, io mem 0xcfffe000
[ 0.363317] usb usb2: configuration #1 chosen from 1 choice
[ 0.363392] hub 2-0:1.0: USB hub found
[ 0.363433] hub 2-0:1.0: 3 ports detected
[ 0.363928] ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 12
[ 0.363938] PCI: setting IRQ 12 as level-triggered
[ 0.363948] ohci_hcd 0000:00:02.3: PCI INT A -> Link[LNKH] -> GSI 12 (level, low) -> IRQ 12
[ 0.363995] ohci_hcd 0000:00:02.3: OHCI Host Controller
[ 0.364189] ohci_hcd 0000:00:02.3: new USB bus registered, assigned bus number 3
[ 0.364251] ohci_hcd 0000:00:02.3: irq 12, io mem 0xcffff000
[ 0.446836] usb usb3: configuration #1 chosen from 1 choice
[ 0.446911] hub 3-0:1.0: USB hub found
[ 0.446946] hub 3-0:1.0: 3 ports detected
[ 0.447076] ohci_hcd 0000:00:0b.0: PCI INT B -> Link[LNKC] -> GSI 11 (level, low) -> IRQ 11
[ 0.447118] ohci_hcd 0000:00:0b.0: OHCI Host Controller
[ 0.447251] ohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 4
[ 0.447310] ohci_hcd 0000:00:0b.0: irq 11, io mem 0xcfff9000
[ 0.454775] ata1.00: ATA-7: Maxtor 6L080P0, BAJ41G20, max UDMA/133
[ 0.454785] ata1.00: 160086528 sectors, multi 16: LBA48
[ 0.470468] ata1.00: configured for UDMA/100
[ 0.538403] usb usb4: configuration #1 chosen from 1 choice
[ 0.538478] hub 4-0:1.0: USB hub found
[ 0.538512] hub 4-0:1.0: 2 ports detected
[ 0.538641] ohci_hcd 0000:00:0b.1: PCI INT C -> Link[LNKD] -> GSI 5 (level, low) -> IRQ 5
[ 0.538686] ohci_hcd 0000:00:0b.1: OHCI Host Controller
[ 0.538847] ohci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 5
[ 0.538900] ohci_hcd 0000:00:0b.1: irq 5, io mem 0xcfffa000
[ 0.626959] usb usb5: configuration #1 chosen from 1 choice
[ 0.627037] hub 5-0:1.0: USB hub found
[ 0.627072] hub 5-0:1.0: 2 ports detected
[ 0.627572] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 5
[ 0.627585] ohci_hcd 0000:00:0b.2: PCI INT D -> Link[LNKA] -> GSI 5 (level, low) -> IRQ 5
[ 0.627634] ohci_hcd 0000:00:0b.2: OHCI Host Controller
[ 0.627817] ohci_hcd 0000:00:0b.2: new USB bus registered, assigned bus number 6
[ 0.627875] ohci_hcd 0000:00:0b.2: irq 5, io mem 0xcfffb000
[ 0.718653] usb usb6: configuration #1 chosen from 1 choice
[ 0.718732] hub 6-0:1.0: USB hub found
[ 0.718767] hub 6-0:1.0: 2 ports detected
[ 0.718887] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.719116] PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 0.719122] PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.719339] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.725050] mice: PS/2 mouse device common for all mice
[ 0.725526] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 0.725564] rtc0: alarms up to one month, 114 bytes nvram
[ 0.725796] device-mapper: uevent: version 1.0.3
[ 0.726210] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 0.726441] device-mapper: multipath: version 1.1.0 loaded
[ 0.726449] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.728469] EISA: Probing bus 0 at eisa.0
[ 0.728573] EISA: Detected 0 cards.
[ 0.728581] cpuidle: using governor ladder
[ 0.728586] cpuidle: using governor menu
[ 0.729449] TCP cubic registered
[ 0.729776] NET: Registered protocol family 10
[ 0.730598] lo: Disabled Privacy Extensions
[ 0.731162] NET: Registered protocol family 17
[ 0.731282] Using IPI No-Shortcut mode
[ 0.731593] registered taskstats version 1
[ 0.732002] rtc_cmos 00:02: setting system clock to 2010-09-17 08:38:08 UTC (1284712688)
[ 0.732011] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.732015] EDD information not available.
[ 0.745928] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.900439] isapnp: No Plug & Play device found
[ 0.900851] scsi 0:0:0:0: Direct-Access ATA Maxtor 6L080P0 BAJ4 PQ: 0 ANSI: 5
[ 0.901297] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 0.901769] sd 0:0:0:0: [sda] 160086528 512-byte logical blocks: (81.9 GB/76.3 GiB)
[ 0.901893] sd 0:0:0:0: [sda] Write Protect is off
[ 0.901900] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.901959] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.902409] sda: sda1 sda2 < sda5 >
[ 0.972457] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.096441] usb 6-2: new low speed USB device using ohci_hcd and address 2
[ 1.277821] Freeing initrd memory: 12797k freed
[ 1.324431] ata2.00: ATAPI: CREATIVECD3630E, AC101, max MWDMA2, CDB intr
[ 1.340293] ata2.00: configured for PIO4
[ 1.342630] scsi 1:0:0:0: CD-ROM CREATIVE CD3630E AC101 1.01 PQ: 0 ANSI: 5
[ 1.351467] sr0: scsi3-mmc drive: 4x/32x cd/rw xa/form2 cdda tray
[ 1.351479] Uniform CD-ROM driver Revision: 3.20
[ 1.351798] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.351965] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.352212] Freeing unused kernel memory: 620k freed
[ 1.354203] Write protecting the kernel text: 4540k
[ 1.354249] Write protecting the kernel read-only data: 1668k
[ 1.381817] usb 6-2: configuration #1 chosen from 1 choice
[ 1.430587] udev: starting version 151
[ 1.861598] Floppy drive(s): fd0 is 1.44M
[ 1.882283] FDC 0 is a post-1991 82077
[ 2.028179] Linux agpgart interface v0.103
[ 2.057330] sis900.c: v1.08.10 Apr. 2 2006
[ 2.057787] ACPI: PCI Interrupt Link [LNKG] enabled at IRQ 11
[ 2.057800] sis900 0000:00:03.0: PCI INT A -> Link[LNKG] -> GSI 11 (level, low) -> IRQ 11
[ 2.058769] 0000:00:03.0: Realtek RTL8201 PHY transceiver found at address 1.
[ 2.068109] 0000:00:03.0: Using transceiver found at address 1 as default
[ 2.131380] eth0: SiS 900 PCI Fast Ethernet at 0xd400, IRQ 11, 00:07:95:34:2c:7e
[ 2.131478] agpgart-sis 0000:00:00.0: SiS chipset [1039/0735]
[ 2.203428] agpgart-sis 0000:00:00.0: AGP aperture is 64M @ 0xd0000000
[ 2.273219] [drm] Initialized drm 1.1.0 20060810
[ 2.289286] usbcore: registered new interface driver hiddev
[ 2.318327] input: Microsoft Microsoft Wheel Mouse OpticalĀ® as /devices/pci0000:00/0000:00:0b.2/usb6/6-2/6-2:1.0/input/input4
[ 2.319255] generic-usb 0003:045E:0040.0001: input,hidraw0: USB HID v1.00 Mouse [Microsoft Microsoft Wheel Mouse OpticalĀ®] on usb-0000:00:0b.2-2/input0
[ 2.319387] usbcore: registered new interface driver usbhid
[ 2.319833] usbhid: v2.6:USB HID core driver
[ 2.377176] nouveau 0000:01:00.0: PCI INT A -> Link[LNKA] -> GSI 5 (level, low) -> IRQ 5
[ 2.389107] [drm] nouveau 0000:01:00.0: Detected an NV10 generation card (0x011000a1)
[ 2.389313] [drm] nouveau 0000:01:00.0: Attempting to load BIOS image from PROM
[ 2.530589] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 2.530972] [drm] nouveau 0000:01:00.0: BMP BIOS found
[ 2.530978] [drm] nouveau 0000:01:00.0: BMP version 5.17
[ 2.530985] [drm] nouveau 0000:01:00.0: Bios version 03.11.00.18
[ 2.530993] [drm] nouveau 0000:01:00.0: Found Display Configuration Block version 1.2
[ 2.530999] [drm] nouveau 0000:01:00.0: No useful information in BIOS output table; adding all possible outputs
[ 2.531005] [drm] nouveau 0000:01:00.0: Probing TV encoders on I2C bus: 1
[ 2.532953] [drm] nouveau 0000:01:00.0: Detected TV encoder: ch7006
[ 2.533359] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0x07FE
[ 2.533380] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0x0EA7
[ 2.533392] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0x0819
[ 2.533420] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0x0E4E
[ 2.533433] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0x08AC
[ 2.533441] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 5 at offset 0x09BB
[ 2.533469] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 6 at offset 0x08DA
[ 2.533492] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 7 at offset 0x0956
[ 2.552254] [TTM] Zone kernel: Available graphics memory: 443690 kiB.
[ 2.552261] [TTM] Zone highmem: Available graphics memory: 513294 kiB.
[ 2.552297] [drm] nouveau 0000:01:00.0: 32 MiB VRAM
[ 2.552423] agpgart-sis 0000:00:00.0: AGP 2.0 bridge
[ 2.552457] agpgart-sis 0000:00:00.0: putting AGP V2 device into 4x mode
[ 2.552527] nouveau 0000:01:00.0: putting AGP V2 device into 4x mode
[ 2.552534] [drm] nouveau 0000:01:00.0: 64 MiB GART (aperture)
[ 2.552896] [drm] nouveau 0000:01:00.0: Allocating FIFO number 0
[ 2.554570] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 0
[ 2.554604] [drm] nouveau 0000:01:00.0: Initial CRTC_OWNER is 0
[ 2.554619] [drm] nouveau 0000:01:00.0: Saving VGA fonts
[ 2.597644] [drm] nouveau 0000:01:00.0: Probing TV encoders on I2C bus: 1
[ 2.598576] [drm] nouveau 0000:01:00.0: Detected TV encoder: ch7006
[ 2.610951] ch7006 0-0075: Detected version ID: 40
[ 2.613614] [drm] nouveau 0000:01:00.0: Detected a VGA connector
[ 2.613941] [drm] nouveau 0000:01:00.0: Detected a TV connector
[ 2.709055] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on vga encoder (output 0)
[ 2.709067] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on TV encoder (output 1)
[ 2.869850] [drm] nouveau 0000:01:00.0: allocated 1680x1050 fb: 0x49000, bo f7121800
[ 2.870409] fb0: nouveaufb frame buffer device
[ 2.870417] registered panic notifier
[ 2.870437] [drm] Initialized nouveau 0.0.15 20090420 for 0000:01:00.0 on minor 0
[ 2.878221] vga16fb: initializing
[ 2.878244] vga16fb: mapped to 0xc00a0000
[ 2.878259] vga16fb: not registering due to another framebuffer present
[ 2.960060] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on TV encoder (output 1)
[ 2.970392] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on vga encoder (output 0)
[ 2.970401] [drm] nouveau 0000:01:00.0: Output VGA-1 is running on CRTC 0 using output @
[ 2.970416] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on TV encoder (output 1)
[ 2.974337] Console: switching to colour frame buffer device 210x65
[ 3.546471] xor: automatically using best checksumming function: pIII_sse
[ 3.564027] pIII_sse : 1726.000 MB/sec
[ 3.564033] xor: using function: pIII_sse (1726.000 MB/sec)
[ 3.576710] device-mapper: dm-raid45: initialized v0.2594b
[ 3.865826] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 6.488893] Adding 3004408k swap on /dev/sda5. Priority:-1 extents:1 across:3004408k
[ 7.369731] udev: starting version 151
[ 8.926641] sis630_smbus 0000:00:02.0: SIS630 comp. bus not detected, module not inserted.
[ 9.039554] sis96x_smbus 0000:00:02.1: SiS96x SMBus base address: 0x0c00
[ 9.039572] ACPI: resource 0000:00:02.1 [0xc00-0xc1f] conflicts with ACPI region SMRG [0xc00-0xc1f]
[ 9.039577] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 9.039789] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 9.068487] lp: driver loaded but no devices found
[ 9.101849] parport_pc 00:09: reported by Plug and Play ACPI
[ 9.101927] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[ 9.192576] lp0: using parport0 (interrupt-driven).
[ 9.268135] gameport: NS558 PnP Gameport is pnp00:0a/gameport0, io 0x201, speed 648kHz
[ 9.418990] ppdev: user-space parallel port driver
[ 10.087406] type=1505 audit(1284712697.853:2): operation="profile_load" pid=529 name="/sbin/dhclient3"
[ 10.088164] type=1505 audit(1284712697.856:3): operation="profile_load" pid=529 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 10.089432] type=1505 audit(1284712697.856:4): operation="profile_load" pid=529 name="/usr/lib/connman/scripts/dhclient-script"
[ 11.687071] Intel ICH 0000:00:02.7: PCI INT C -> Link[LNKC] -> GSI 11 (level, low) -> IRQ 11
[ 12.016150] intel8x0_measure_ac97_clock: measured 55829 usecs (2685 samples)
[ 12.016161] intel8x0: clocking to 48000
[ 12.590677] type=1505 audit(1284712700.358:5): operation="profile_load" pid=651 name="/usr/share/gdm/guest-session/Xsession"
[ 12.603084] type=1505 audit(1284712700.368:6): operation="profile_replace" pid=654 name="/sbin/dhclient3"
[ 12.603748] type=1505 audit(1284712700.368:7): operation="profile_replace" pid=654 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 12.611841] type=1505 audit(1284712700.376:8): operation="profile_replace" pid=654 name="/usr/lib/connman/scripts/dhclient-script"
[ 12.878008] type=1505 audit(1284712700.644:9): operation="profile_load" pid=658 name="/usr/bin/evince"
[ 12.888209] type=1505 audit(1284712700.656:10): operation="profile_load" pid=658 name="/usr/bin/evince-previewer"
[ 12.894216] type=1505 audit(1284712700.660:11): operation="profile_load" pid=658 name="/usr/bin/evince-thumbnailer"
[ 16.764968] eth0: Media Link On 100mbps full-duplex
[ 18.166786] [drm] nouveau 0000:01:00.0: Allocating FIFO number 1
[ 18.169879] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 1
[ 25.330487] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on vga encoder (output 0)
[ 25.359482] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on TV encoder (output 1)
[ 25.361134] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on TV encoder (output 1)
[ 25.371339] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on vga encoder (output 0)
[ 25.371348] [drm] nouveau 0000:01:00.0: Output VGA-1 is running on CRTC 0 using output @
[ 25.372158] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on TV encoder (output 1)
[ 25.612061] eth0: no IPv6 routers present
[ 54.934197] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
I have a AMD duron 1.2 G and 1024 Ram
I'm thinking to reinstal but if anyone can help me before ?
Thanks Marco
17 Sep 2010 09:48 #4228 by alex_joni
17 Sep 2010 09:58 #4229 by marcguenel
Replied by marcguenel on topic Re:Error EMC2
Many Thanks:
I will !!
Regards
17 Sep 2010 10:16 #4230 by marcguenel
Same problem :)
Answer from terminal when update grub :
marco@PC-Atelier:~$ update-grub
/usr/sbin/grub-mkconfig: You must run this as root
Marco
17 Sep 2010 11:36 #4232 by marcguenel
Many thanks Alex
I have redone the command under root and it work !
I forgot to go under root by :
sudo -i
Many thanks for your help !
Marco
Time to create page: 0.246 seconds
