SSI ABS Encoder
- nhanpham
06 May 2021 04:15 - 06 May 2021 04:29 #208080
by nhanpham
SSI ABS Encoder was created by nhanpham
hi everyone,
I have 1 ssi abs encoder 12 bit.
i connected it to mesa board and got data.
my encoder is single turn, binary code, with 4096 res/rev.The data is incorrect when i restart linuxcnc
Exam: my data is 0-3072 then it restores correctly
but if my data is 3073-4096 then whenit recovers negative numbers from -1024 ->-1
It's abs encoder
can you help me check it, pls?
thank you very much
loadrt hm2_eth board_ip="10.10.10.10" config="ssi_chan_0=steps%4bzencoder%12e num_encoders=1 num_pwmgens=0 num_stepgens=4 enable_raw"
setp hm2_7i80.0.dpll.02.timer-us -120
setp hm2_7i80.0.ssi.00.frequency-khz 300
setp hm2_7i80.0.ssi.00.timer-number 2
setp hm2_7i80.0.ssi.00.zencoder.scale 535
setp hm2_7i80.0.ssi.00.zencoder.counts-per-rev 4096
net z-pos-fbss <= hm2_7i80.0.ssi.00.zencoder.position
net z-pos-rawcountsww <= hm2_7i80.0.ssi.00.zencoder.rawcounts
net J2pos => joint.2.motor-pos-fbExam: my data is 0-3072 then it restores correctly
It's abs encoder
thank you very much
Last edit: 06 May 2021 04:29 by nhanpham.
- Thank you received: 4658
06 May 2021 05:34 #208085
Replied by andypugh on topic SSI ABS Encoder
It sounds like the encoder wrap handling is going wrong.
Does the encoder actually do more than one revolution in use? If not then you could try setting the "m" (multi-turn) flag in the config string.
The code that handles absolute encoders is actually re-used smart-serial code:
github.com/LinuxCNC/linuxcnc/blob/master...mot2/sserial.c#L1980
I am a bit surprised that the wrap happens at 3072, though. I would expect it at 2048.
The following user(s) said Thank You: nhanpham
- nhanpham
06 May 2021 06:32 - 06 May 2021 06:33 #208090
by nhanpham
Yes, it happens at 3072, about 1/4 one revolution.
my encoder is sigle-turn. I tried setting the 'm' code but it doesn't help.
Replied by nhanpham on topic SSI ABS Encoder
Last edit: 06 May 2021 06:33 by nhanpham.
- nhanpham
06 May 2021 06:36 - 06 May 2021 06:46 #208091
by nhanpham
is My setting correct?
loadrt hm2_eth board_ip = "10.10.10.10" config = "ssi_chan_0 = steps% 4bzencoder% 12e num_encoders = 1 num_pwmgens = 0 num_stepgens = 4 enable_raw"
#setp hm2_7i80.0.ssi.00.zencoder.index-enable 0
setp hm2_7i80.0.ssi.00.zencoder.counts-per-rev 4095
#net z-pos-fb => joint.2.motor-pos-fb
net J2pos => joint.2.motor-pos-fbis My setting correct?
Last edit: 06 May 2021 06:46 by nhanpham.
06 May 2021 07:56 #208097
counts-per-rev should probably be 4096. But that isn't the problem.
Setting it to a much larger number might be an interesting experiment, though.
Is there any way to see the raw data from the encoder? if no-wrap is active then the driver doesn't do very much with the data that comes back. Is it possible that what you see is the actual numbers from the encoder?
I think you can use "enable_raw" in the loadrt hostmot2 line of the hal and peek at the actual register values on the FPGA.
linuxcnc.org/docs/2.8/html/man/man9/hostmot2.9.html#Raw%20Mode
I have attached the hostmot2 register map so that you know where to look.
06 May 2021 08:01 #208099
Specifically this bit..
SSI Data Register0, right justifed. Writes to this location will start a
read cycle for the specific SSI interface addressed
0x6900 SSI data register0 channel 0
0x6904 SSI data register0 channel 1
0x6908 SSI data register0 channel 2
0x690C SSI data register0 channel 3
0x6A00 SSI data register1 channel 0
0x6A04 SSI data register1 channel 1
0x6A08 SSI data register1 channel 2
0x6A0C SSI data register1 channel 3Please Log in or Create an account to join the conversation.
- nhanpham
06 May 2021 08:29 #208105
by nhanpham
i have used an oscilloscope to see data. it returns a correct value from 0->4095
- Thank you received: 5337
06 May 2021 08:39 - 06 May 2021 08:42 #208106
Replied by PCW on topic SSI ABS Encoder
Sounds like the data is corrupted/shifted
inverted clock maybe?
Andys raw read suggestion is good
For debugging, its important to see what the FPGA reads
Last edit: 06 May 2021 08:42 by PCW.
- nhanpham
06 May 2021 09:01 #208112
by nhanpham
Is it correct?
The values return from 0x0000000->0x0000ffff for 0->4096
thank you for your helping
SSI Data Register0, right justifed. Writes to this location will start a read cycle for the specific SSI interface addressed 0x6900 SSI data register0 channel 0 0x6904 SSI data register0 channel 1 0x6908 SSI data register0 channel 2 0x690C SSI data register0 channel 3 ... 0x6A00 SSI data register1 channel 0 0x6A04 SSI data register1 channel 1 0x6A08 SSI data register1 channel 2 0x6A0C SSI data register1 channel 3
Is it correct?
setp hm2_7i80.0.raw.read_address 0x6900
show pin hm2_7i80.0.read_dataThe values return from 0x0000000->0x0000ffff for 0->4096
06 May 2021 09:14 #208116
What does hm2_7i80.0.ssi.00.zencoder.rawcounts
show?
show?
