SSI ABS Encoder
08 May 2021 00:56 #208273 by PCW
Replied by PCW on topic SSI ABS Encoder
What does:
halcmd show all | grep ssi
show?
08 May 2021 01:31 #208276 by PCW
I ask because SSI support has been working for at least 10 years
though possible only with multi-turn encoders
  • nhanpham
  • nhanpham's Avatar Topic Author
  • Senior Member
  • Senior Member
08 May 2021 02:06 - 08 May 2021 02:07 #208279 by nhanpham
Replied by nhanpham on topic SSI ABS Encoder
The scalemax para should be accessed by '''hm2_7i80.0.ssi.00.zencoder-scalemax```
It's my mistake. I read manual and it is hm2_7i80.0.ssi.00.zencoder.scalemax
it is :
~/linuxcnc-dev/src $ halcmd show all | grep ssi
    29  bit   OUT         FALSE  hm2_7i80.0.ssi.00.data-invalid
    29  bit   OUT          TRUE  hm2_7i80.0.ssi.00.steps
    29  bit   OUT         FALSE  hm2_7i80.0.ssi.00.steps-not
    29  float OUT    0.02197802  hm2_7i80.0.ssi.00.zencoder ==> z-pos-fbss
                         <== hm2_7i80.0.ssi.00.zencoder
    29  bit   RW          FALSE  hm2_7i80.0.ssi.00.clock.invert_output
    29  bit   RW          FALSE  hm2_7i80.0.ssi.00.clock.is_opendrain
    29  float RW            300  hm2_7i80.0.ssi.00.frequency-khz
    29  u32   RW     0x00000002  hm2_7i80.0.ssi.00.timer-number
    29  float RW              1  hm2_7i80.0.ssi.00.zencoder-scalemax
 hm2_7i80.0.ssi.00.clock.invert_output            hm2_7i80.0.gpio.012.invert_output
 hm2_7i80.0.ssi.00.clock.is_opendrain             hm2_7i80.0.gpio.012.is_opendrain
Last edit: 08 May 2021 02:07 by nhanpham.
  • nhanpham
  • Senior Member
  • Senior Member
08 May 2021 02:15 #208280 by nhanpham
hi,
in manual itt is:
b: (Boolean) No Parameters.
u: (Unsigned)
(float, r/w) hm2_XXXX.N.ssi.MM.<name>.scalemax. The scaling factor for the
channel.
s: (Signed)
(float, r/w) hm2_XXXX.N.ssi.MM.<name>.scalemax. The scaling factor for the channel.
f: (bitField): No parameters.
maybe, we need to change this in the manual.
Sorry for my mistake.
thank you very much
09 May 2021 19:44 #208410 by andypugh
Replied by andypugh on topic SSI ABS Encoder
I saw your pull request for the docs.
Looking through the code, there is no occurence of .scalemax anywhere, so we can just change the doc to -scalemax.
Time to create page: 0.127 seconds
