Remap M6 with rackchange.NGC
- mucy007
11 May 2021 12:08 #208566
by mucy007
Remap M6 with rackchange.NGC was created by mucy007
Hello Dear Linuxcnc community.
Yet again I am stuck. When Executing M6 command after opening drawbar I get warning : Drawbar not open. I checket for function and my I/O are correct. (Tried using atc toggle)
I suspect it has something to do with this part of INI :
[ATC_PINS]
# motion.digital-out-NN pins
# Pin to trigger air blast at TS
CLEAN_TS = 00
# Pin to toogle drawbar, unclamp tool
ATC_OPEN = 01
# motion.digital-in-NN pins
# Spindle specific signals for checking the status of the drawbar and the tool
# Tool pin; low = tool status unknown; high = tool inserted
SENSOR_TOOL = 0
# Drawbar pin; low = closed; high = open
SENSOR_DRAWBAR = 1
I dont understand what PIN does number 1 represents by SENSOR DRAWBAR ?
In my io.hal inputs are like this :
# --- Jianken Spindle Sensor 1 ---
# Mapping sensor 1 in ATC spindle: signal high = tool clamped
net spindle_tool <= hm2_7i96.0.gpio.000.in
# ---DI-11 ---
# --- Jianken Spindle Sensor 2 ---
# Mapping sensor 2 in ATC spindle: signal high = draw bar down (ready to receive tool)
net spindle_drawbar <= hm2_7i96.0.gpio.001.in
So, stupid me, i also tried to put in PIN nr. 000 and 001 - doesnt work. Or is that no Input Pin what you define in INI
Thank you,
Best regards
[ATC_PINS]
CLEAN_TS = 00
ATC_OPEN = 01
SENSOR_TOOL = 0
SENSOR_DRAWBAR = 1
# ---DI-11 ---
Thank you,
Best regards
- chris@cnc
- Thank you received: 140
11 May 2021 14:07 #208574
by chris@cnc
Replied by chris@cnc on topic Remap M6 with rackchange.NGC
I guess the sensor is broken. After opening the drawbar, the sensor has to switch off and it doesn't.
The logic probably checks a signal change during the tool change
- mucy007
11 May 2021 15:16 #208577
by mucy007
Replied by mucy007 on topic Remap M6 with rackchange.NGC
Hello
;Check if Release was ok by watching pin to turn high (L3)
M66 P #<_ini[ATC_PINS]SENSOR_DRAWBAR> L0
Thats the part that checks value.
SENSOR_DRAWBAR is defined in INI.
I didnt find any info on what value should I put into: SENSOR_DRAWBAR
Sensor is working properly.
- Thank you received: 4658
12 May 2021 15:29 #208648
The only person who would know is the person who wrote your INI file. Where did it come from?
But, we can probably guess.
It appears that SENSOR_DRAWBAR needs to be the number of the G-code digital input that the drawbar sensor is connected to.
You havein the HAL andin the INI, but do you also havein the HAL?
(Reference info: linuxcnc.org/docs/2.8/html/man/man9/motion.9.html )
Replied by andypugh on topic Remap M6 with rackchange.NGC
You have
net spindle_drawbar <= hm2_7i96.0.gpio.001.in# Drawbar pin; low = closed; high = open
SENSOR_DRAWBAR = 1net spindle_drawbar motion.digital-in-01(Reference info: linuxcnc.org/docs/2.8/html/man/man9/motion.9.html )
The following user(s) said Thank You: mucy007
- mucy007
17 May 2021 13:28 #209254
by mucy007
Hello.
Thank you for showing me the way. Now i get it.
Time to create page: 0.179 seconds
