Spindle Orient dual mode (velocity and position) with parport
18 May 2021 05:23 - 18 May 2021 05:24 #209325 by fery15sty
Can anyone help me ..
how to make a spindle orient configuration with dual mode velocity and position using parport
My expected way of working:
- velocity mode
example: M3 S300
The spindle rotates continuously at a speed of 300rpm
- position mode
example: M19 R90
The spindle will rotate by 90 deg
Hardware that I use:
1. Chinese 5axis breakout-board (Parallel port)
2. Encoder (ABZ)
3. Stepper motor
4.TB6600 stepper driver
5. PSU for TB6600
Maybe someone can help me?
Last edit: 18 May 2021 05:24 by fery15sty.
19 May 2021 07:40 #209498 by andypugh
One way to do this is with two separate step generators, one for spindle / velocity mode and one for position mode.
Alternatively, a single step generator in velocity mode and two different control inputs to that can also work (direct spindle speed and position via a PID component). In the latter case you can just add together the two inputs before sending to the velocity command pin.
Enable / disable the position PID using the spindle.0.orient* pins.
But, you will need a spindle encoder.
Time to create page: 0.105 seconds
