Cannot use ethercat terminals sending more than 1 byte.
5 years 4 months ago #211488 by Grotius
Hi Stormhold,
It looks like a run error.
Maybe add some include's to the lcec_main.c, and some lcec names + data over there. I did not do that. :woohoo:
Attached my qt project.
1. open -> qt-test.creator
2. edit config.mk (Set path to the halcomplie executable and lcnc main makefile)
3. edit configure.mk (Set path to the halcomplie executable).
4. edit qt-test.includes (Set path to several includes)
5. Cntr+r (run)
6. When compiled you get the lcec.so and lcec_conf.
7. When doing a new compile just delete the lcec.so and lcec_conf before. ( or do a make clean )
8. Warning's about "set an executable in the custom run configuration" are not important.
5 years 4 months ago - 5 years 4 months ago #211507 by Stormholt
@db1981 i believe i add the drivers correctly, i have attached files i edit when adding new drivers
Furthermore, this i how i build after changes:
cd /home/linuxcnc-ethercat sudo make clean sudo make sudo make install sudo cp -f src/lcec_conf ~/vaerkscnc-dev/config/ #Same path as .ini sudo cp -f src/lcec.so /usr/lib/linuxcnc/modules/
Last edit: 5 years 4 months ago by Stormholt.
5 years 4 months ago #211514 by Stormholt
@Grotius i dont have/cant find similar paths for the include files:
May have something to do with linuxcnc being installed from apt.
The most similar i have are:
/usr/include/linuxcnc
/usr/lib/linuxcnc
/home/linuxcnc-ethercat/src
With which i get an error: :-1: error: You need to set an executable in the custom run configuration.
I have checked that the .mk files points to an executable halcompile
5 years 4 months ago - 5 years 4 months ago #211519 by Grotius
Hi Stormhold,
You are almost there ! Hold on.
This is no issue. Just look if Qt has compiled the lcec.so.
Qt gives this message because it expect's to start a executable like a program. But there is no. It's just a library.
I get the same message. I just check if lcec.so is compiled.
When for example i start a executable like a c++ hal program, you can set this in the build configuration.
I don't get the message. And the executable program
is then designed to load the lcec.so and then check the library values. Somewhere i did a example of that in a bash file.
You can start a simple bash file to check your library values. Like a bash file that does a halcommand with loadrt lcec.so
The most important includepath is that where halcompile lives. Mabye in c: $ sudo find . -name halcompile
This will problably be a /bin dir. For info, halcompile is a python program. So you could do a : $ python3 halcompile ...
May have something to do with linuxcnc being installed from apt..
Ah. If you have no dev version. You have to check your c: path for the spread around files. :blink:
That's why i suggested a lcnc install in opt/linuxcnc before. Andy is with me.
Last edit: 5 years 4 months ago by Grotius.
5 years 4 months ago - 5 years 4 months ago #211596 by Stormholt
Right, *facepalm* you asked me to ignore that error.
lcec.so and lcec_conf are generated just fine. However i receive the same error as with my own attempt: "lcec: dlopen: /usr/lib/linuxcnc/modules/lcec.so: undefined symbol: lcec_ax5200_init"
I could try commenting all other drivers in the lcec_conf.c an .h as db1981 pointed out
EDIT: tried this with the EL2004(1byte), El3202(8byte) and El1002(1byte), and received 9 bytes. the error persists :-/
5 years 4 months ago #211597 by Stormholt
I was able to get correct amount of byte in the stack 2004, 2014, 1002, by making the el2014 a generic type writing full mapping in the xml file - following this guide
I could control digital out correctly, but some of the diagnostic data from the el2014 did not work such as the "open load" signal
Time to create page: 0.095 seconds
