M19 and spindle-index-enable issues
- Thank you received: 2177
18 Mar 2025 09:55 #324210
Replied by Aciera on topic M19 and spindle-index-enable issues
Constantly forcing index-enable low would explain the issue with G33.1 in the post above:
forum.linuxcnc.org/10-advanced-configura...sues?start=20#282461
Have you tried using spindle synchronized motion (eg g33 or g33.1)?
18 Mar 2025 09:58 #324211
Just so we are on the same page here is my version:
- scda
- Thank you received: 3
18 Mar 2025 15:26 - 18 Mar 2025 15:51 #324227
by scda
Replied by scda on topic M19 and spindle-index-enable issues
What makes me wonder is why constantly forcing index-enable low does not cause a problem for you.
You are right. I haven't used G33.1 yet. Will test it soon.
But from the looks of it, this is not easily solveable --> need to disconnect the index somehow...
EDIT: Could we write a switch component that passes the signal in both directions (similar to mux2 but bidirectional... ) ?
EDIT2: The easiest solution for this is to probably just install a optical sensor as a second index signal... and then use this for indexing in M19 or for G33.1 ?
Last edit: 18 Mar 2025 15:51 by scda.
19 Mar 2025 01:21 #324263
the index-enable pin is of type 'io' which _is_ bidirectional. All you need to do is move the line 'index-enable = 0; ' inside the 'if (enable)' block as in my version (or possibly just remove it as the user in the post I linked above.
The following user(s) said Thank You: scda
- scda
22 Mar 2025 07:08 #324539
by scda
Thanks for that.
Will test it this weekend.
Dave
Dave
02 Apr 2025 16:28 #325549
Replied by andypugh on topic M19 and spindle-index-enable issues
As to why adding 16 to the mode doesn't work...
I guess that the problem comes if the orient.0.mode pin is connected to spindle.N.orient-mode, I didn't realise that the P number had a limit check on it.
If it is controlled by a "setp" in the HAL then it should be fine (with the spindle.N.orient-mode pin left unconnected)
That means that you can't change the mode with the P command in M19. I don't know if that is really a problem, though?
Time to create page: 0.879 seconds
