- Configuring LinuxCNC
- Advanced Configuration
- Stepper - homing plus index encoder v2.9 no encoder reset ini flag
- Thank you received: 7505
10 Jul 2021 04:48 #214170
Replied by tommylight on topic Stepper - homing plus index encoder v2.9 no encoder reset ini flag
Just the bit file.
The following user(s) said Thank You: evengravy
- evengravy
- Thank you received: 4
10 Jul 2021 05:37 #214171
by evengravy
Replied by evengravy on topic Stepper - homing plus index encoder v2.9 no encoder reset ini flag
Perfect. Mesa is flashed, didn't encounter any issues there. Thanks again for this PCW. I did a quick test of the existing functionality and everything is working just fine. Lastly I just have to configure it.
So on the INI side I need to set HOME_USE_INDEX = YES and set HOME_INDEX_NO_ENCODER_RESET = YES
On the HAL side, could you direct me to any info of what would be needed there to make the relevant net connections?
- Thank you received: 5337
10 Jul 2021 12:05 - 10 Jul 2021 12:11 #214195
Replied by PCW on topic Stepper - homing plus index encoder v2.9 no encoder reset ini flag
Makes no sense here
In the hal file, motions per joint index enables need to connect to
the corresponding stepgens index enables and the PID index enable pins
Makes no sense here
Last edit: 10 Jul 2021 12:11 by PCW.
- evengravy
10 Jul 2021 13:13 #214201
by evengravy
Hey,
"HOME_INDEX_NO_ENCODER_RESET = YES
Makes no sense here"
Okay I'll leave out. Thanks.
So "motions per joint index enable" would be "joint.n.index-enable" is that right? Or something else?
The stepgen index enable I haven't come across before, does this have a built in naming structure i.e. stepgen.n.index-enable (similar to encoder.n.index-enable mentioned in the previously mentioned docs) or do I reference the gpio input pin directly here?
I see that pid.x.index-enable is tied to x-index-enable so I can see that clearly.
Sorry for all the confusion, since this is brand new functionality I'm a bit lost to be honest.
10 Jul 2021 13:24 #214203
Yes, something like
hm2_7i96.0.stepgen.00.index-enable
If you want to know all stepgen related pins and parameters, you can type
halcmd show all hm2_7i96.0.stepgen
in a terminal window
- evengravy
10 Jul 2021 13:53 - 10 Jul 2021 13:54 #214207
by evengravy
I found I have hm2_7i96.0.stepgen.00.index-enable and hm2_7i96.0.stepgen.01.index-enable. Thanks.
Does this look right then:
net Xindex-enable hm2_7i96.0.stepgen.00.index-enable <=> joint.0.index-enable
net Index-enable hm2_7i96.0.stepgen.01.index-enable <=> joint.1.index-enable
(I haven't made any linkages to the gpio pins as I assume that is handled on the firmware now is that correct?)
There is already a linkage to the PID in the main HAL file:
net x-index-enable <=> pid.x.index-enable
net z-index-enable <=> pid.z.index-enable
Are those okay as is or do I need to link to those also?
Last edit: 10 Jul 2021 13:54 by evengravy.
- evengravy
10 Jul 2021 14:15 - 10 Jul 2021 15:20 #214209
by evengravy
Hey,
I gave this a try and it seems to work as expected. Moves to switch then to index before homing/zero. Thanks a lot PCW.
I didn't make any new net linkages to pid. I just added the lines as above to custom HAL.
I really appreciate your help on this PCW, support is over and above what I would expect. I just went and bought another 7i96 for my router, I'll never use a BOB again.
One small related question, if you don't mind: is there the ability to choose the direction of travel the controller takes when searching for the proximity, or is that fixed. On my Z axis it moves into the switch when searching for the proximity, but moves visa versa on the X axis. It doesn't matter a huge amount, I'm just a little OCD.
Thanks to you also Tommy, appreciated!
Last edit: 10 Jul 2021 15:20 by evengravy.
10 Jul 2021 16:13 #214215
You can change all the directions by changing the signs of the various homing velocities:
linuxcnc.org/docs/html/config/ini-homing.html#_homing_sequence
The following user(s) said Thank You: Lcvette
- evengravy
10 Jul 2021 16:29 - 10 Jul 2021 16:30 #214219
by evengravy
Ah okay, I'll have a play around. I knew this was the case for home search vel.
It's homing against main switch correctly but once it triggers moving away from switch to hit the index sensor. Im guessing i need to invert the home latch vel sign on that axis then. I'll play around tomorrow. Ty
Last edit: 10 Jul 2021 16:30 by evengravy.
Time to create page: 0.664 seconds
