Ethercat Setup - Beginners question
- Columbo
10 Jul 2021 09:26 #214180
by Columbo
Ethercat Setup - Beginners question was created by Columbo
Hi guys,
in the last days I read a lot about EtherCAT + LinuxCNC + EL6751 and I know, that
ethercat slaves -v
must bring clean results.
In my case the command above brings results depending on time. So if i check the command several times in the shell (with breaks between pressing ENTER of ~1second) the result is once every slave is 0x00000000(VId and PId), sometimes EK1100 is found (with VId und PId) and EL6751 is not found, sometimes both is found and everything seems fine.
root@fraese:~# ethercat slaves
0 1:0 PREOP + EK1100 EtherCAT-Koppler (2A E-Bus)
1 1:1 PREOP + 0x00000000:0x00000000
0 0:0 ??? + 0x00000000:0x00000000
1 0:1 ??? + 0x00000000:0x00000000
0 1:0 INIT + EK1100 EtherCAT-Koppler (2A E-Bus)
0 1:0 INIT + 0x00000000:0x00000000
1 1:1 PREOP + EL6751 CANopen Master
0 1:0 PREOP + 0x00000000:0x00000000
0 0:0 PREOP + 0x00000000:0x00000000
1 0:1 INIT + 0x00000000:0x00000000
1 1:1 INIT + 0x00000000:0x00000000
uname -r --> 4.19.0-11-rt-amd64
and
ethercat master
root@fraese:~# ethercat master
Master0
Phase: Idle
Active: no
Slaves: 2
Ethernet devices:
Main: 00:0e:0c:72:77:c6 (attached)
Link: UP
Tx frames: 1155551
Tx bytes: 82652516
Rx frames: 946299
Rx bytes: 61064888
Tx errors: 0
Tx frame rate [1/s]: 559 571 578
Tx rate [KByte/s]: 42.6 39.8 40.5
Rx frame rate [1/s]: 438 460 467
Rx rate [KByte/s]: 28.0 28.5 28.9
Common:
Tx frames: 1241098
Tx bytes: 88861057
Rx frames: 1015609
Rx bytes: 65493131
Lost frames: 225489
Loss rate [1/s]: 121 111 111
Frame loss [%]: 21.6 19.4 19.2
Distributed clocks:
Reference clock: None
DC reference time: 0
Application time: 0
May you give me a hint, where my problem is?
If I disconnect the EL6751 the EK1100 is found every time.
Grretings
Columbo
ethercat slaves -v
and
ethercat master
Master0
Phase: Idle
Active: no
Slaves: 2
Ethernet devices:
Link: UP
Tx frames: 1155551
Tx bytes: 82652516
Rx frames: 946299
Rx bytes: 61064888
Tx errors: 0
Common:
Tx frames: 1241098
Tx bytes: 88861057
Rx frames: 1015609
Rx bytes: 65493131
Lost frames: 225489
Distributed clocks:
Application time: 0
Grretings
Columbo
- Columbo
11 Jul 2021 07:05 #214249
by Columbo
Replied by Columbo on topic Ethercat Setup - Beginners question
Hi guys,
I found out what makes the nodes unstable dissappear. Between the EK1100 and the EL6751 there were 2 pcs. KL1104 and 2pcs. KL2114. I removed them from the package and now I can look forward for further experiments.
Time to create page: 0.468 seconds
