Firmware, 5i25
  • Tesremos
  • Tesremos's Avatar Topic Author
  • Senior Member
  • Senior Member
25 Jul 2021 02:38 #215842 by Tesremos
Firmware, 5i25 was created by Tesremos
Okay, so todays project is connecting a little home mill to a 5I25, With a china Abob (one of those generic 5axis parallel port bobs that are very common) and on the second header, 4encoders.
the question, is there firmware for this already? if so, can someone point me at the file name? please.
second question, is in pnconf, is there a way to have pnconf list all of the encoders? or do i have tommanually hand code them after setting the stepgen allocations?
Thank you in advance for any worda of wisdom.
25 Jul 2021 04:25 #215844 by andypugh
Replied by andypugh on topic Firmware, 5i25
Try 5i25_g540_enc.bit
Configuration pin-out:
IO Connections for P3
Pin#  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 1      0   IOPort       None
14      1   IOPort       PWMGen           0        PWM             (Out)
 2      2   IOPort       StepGen          0        Step            (Out)
15      3   IOPort       None
 3      4   IOPort       StepGen          0        Dir             (Out)
16      5   IOPort       StepGen          4        Step            (Out)
 4      6   IOPort       StepGen          1        Step            (Out)
17      7   IOPort       None
 5      8   IOPort       StepGen          1        Dir             (Out)
 6      9   IOPort       StepGen          2        Step            (Out)
 7     10   IOPort       StepGen          2        Dir             (Out)
 8     11   IOPort       StepGen          3        Step            (Out)
 9     12   IOPort       StepGen          3        Dir             (Out)
10     13   IOPort       QCount           0        Quad-A          (In)
11     14   IOPort       QCount           0        Quad-B          (In)
12     15   IOPort       QCount           0        Quad-IDX        (In)
13     16   IOPort       None
IO Connections for P2
 1     17   IOPort       QCount           1        Quad-A          (In)
14     18   IOPort       QCount           1        Quad-B          (In)
 2     19   IOPort       QCount           1        Quad-IDX        (In)
15     20   IOPort       QCount           2        Quad-A          (In)
 3     21   IOPort       QCount           2        Quad-B          (In)
16     22   IOPort       QCount           2        Quad-IDX        (In)
 4     23   IOPort       QCount           3        Quad-A          (In)
17     24   IOPort       QCount           3        Quad-B          (In)
 5     25   IOPort       QCount           3        Quad-IDX        (In)
 6     26   IOPort       QCount           4        Quad-A          (In)
 7     27   IOPort       QCount           4        Quad-B          (In)
 8     28   IOPort       QCount           4        Quad-IDX        (In)
 9     29   IOPort       QCount           5        Quad-A          (In)
10     30   IOPort       QCount           5        Quad-B          (In)
11     31   IOPort       QCount           5        Quad-IDX        (In)
12     32   IOPort       None
13     33   IOPort       None
