(SOLVED) Spindle PID tuning
- spumco
- Thank you received: 905
01 Oct 2021 18:09 #221984
by spumco
Spindle PID tuning was created by spumco
I could use some guidance on getting my spindle commanded speed to match actual speed. I do not have any PID yet, but fiddling with the values a bit changes the response, so I know it's not running open-loop due to pin/signal issues.
Encoder working properly, feedback speed matches actual speed measured with phototachometer.
I have no analog offset or analog gain changes in the VFD.
LCNC Ver 2.8.2
VFD commanded by 0-10V, 4096-count encoder.
P/I/D all set in .ini to 0.0, FF0 = 1.0
The actual speed varies as follows:
(command) - (actual) (percent off)
1000rpm - 828rpm (17.2%)
1500rpm - 1350rpm (10%)
2000rpm - 1867rpm (6.7%)
2500rpm - 2397rpm (4%)
3000rpm - 2916rpm (2.6%)
3500rpm - 3450rpm (1.4%)
4000rpm - 3983rpm (0.4%)
I've read through a number of threads on PID tuning, but any of the values I tried resulted in slow(ish) runaways or significant undershoots. No hunting up/down, however.
Anyone have a suggestion on a starting point?
LCNC Ver 2.8.2
- Thank you received: 5337
01 Oct 2021 18:24 #221985
Replied by PCW on topic Spindle PID tuning
Are the PID command, output, and feedback in RPM or RPS?
(They all have to use the same units or it will not work)
- spumco
01 Oct 2021 20:18 #221988
by spumco
Replied by spumco on topic Spindle PID tuning
Thank you, but can you be more specific? When you refer to 'command', do you mean the pins I was watching (spindle-vel-cmd-rpm and spindle-vel-fb-rpm)?
01 Oct 2021 20:31 - 01 Oct 2021 20:32 #221990
I was referring to the PID pins do they make sense?
That is, is the PID command pin equal to the commanded RPM
and the PID feedback pin equal to the actual RPM?
Does the PID error make sense? (it should be the difference
between the commanded and actual RPM)
Last edit: 01 Oct 2021 20:32 by PCW.
- spumco
01 Oct 2021 20:48 #221991
by spumco
Sorry, I should have noted that I'm still very new at LCNC - this is my first installation ever. I've beed active on the forum for a while trying to get the preliminaries sorted out, but it would help if you were very specific.
"PID command pin" - is that pid.s.command?
Here's what I think you're asking (M3 S1000):
pid.s.command = 1000
pid.s.feedback = 0
spindle-output = 1000
spindle-fb-rpm = 829 (fluctuates +/-3rpm)
spindle-vel-cmd-rpm = 1000
pid.s.feedback = 0
01 Oct 2021 21:21 #221992
pid.s.feedback = 0
and
Indicate that the PID feedback pin is unconnected
and
- spumco
01 Oct 2021 21:30 #221993
by spumco
pid.s.feedback appears to be connected to spindle-vel-fb-rpm-abs, but that signal isn't connected to anything else.
Maybe it would be easier if I posted my HAL and ini.
01 Oct 2021 22:37 - 01 Oct 2021 22:40 #221994
I would change this section:
# Use ACTUAL spindle velocity from spindle encoder
# spindle-velocity bounces around so we filter it with lowpass
# spindle-velocity is signed so we use absolute component to remove sign
# ACTUAL velocity is in RPS not RPM so we scale it.
setp scale.spindle.gain 60
setp lowpass.spindle.gain 1.000000
net spindle-vel-fb-rps => scale.spindle.in
net spindle-fb-rpm scale.spindle.out => abs.spindle.in
net spindle-fb-rpm-abs abs.spindle.out => lowpass.spindle.in
net spindle-fb-rpm-abs-filtered lowpass.spindle.out
To this:
net spindle-vel-fb-rpm => abs.spindle.in
net spindle-vel-fb-rpm-abs abs.spindle.out => lowpass.spindle.in
You could also delete all the scale stuff (loadrt and addf) since the scale
component is not needed.
To this:
Last edit: 01 Oct 2021 22:40 by PCW.
- spumco
01 Oct 2021 22:51 #221995
by spumco
Excellent! now pid.s.feedback matches spindle-vel-fb-rpm
I suppose now I can start adjusting the PID values in the .ini file, right?
Do you have any suggestions on starting points?
01 Oct 2021 22:58 #221996
I guess I would start with a bit of P
(a P term of 1 means an error of 100 RPM means a
correction in the velocity command of 100 RPM )
and then some I
( a I term of 1 means an error of 100 RPM will result in a correction
velocity command of 100 RPM per second)
and then some I
Time to create page: 0.132 seconds
