- Thank you received: 2177
Linuxcnc and Profibus
4 years 2 months ago #249368
Replied by Aciera on topic Linuxcnc and Profibus
Also I just noticed that your cpv module looks more modern than the one i used.
Can you check the part number on yours please?
ie something like CPV10-GE-DI02-8
The following user(s) said Thank You: blauerklappstuhl
4 years 2 months ago - 4 years 2 months ago #249370
And also try with the DIP switch "8" set to OFF.
Edit:
I have run out of time for today.
Edit:
Last edit: 4 years 2 months ago by Aciera.
- blauerklappstuhl
- Thank you received: 6
4 years 2 months ago #249384
by blauerklappstuhl
Replied by blauerklappstuhl on topic Linuxcnc and Profibus
Found the issue: cpv dio1 uses different gse than dio2....took me until 2am this morning. All components are working now too (16input+8output). I will share gse and config later today.
By the way usb to rs485 seems to work ok. When triggering inputs slight delay is recognizable.Baudrate could be higher, but I will try with comport to rs485 later today if there are higher baudrates possible. Pci to rs485 could be an option, but I have no free slot.
4 years 2 months ago #249392
Great, glad you got it working.
- blauerklappstuhl
4 years 2 months ago #250247
by blauerklappstuhl
Short update: I was able to achieve 3mbit with an usb to rs485 adapter with ftdi 232rl chip
- blauerklappstuhl
4 years 2 months ago #250248
by blauerklappstuhl
Next step is to use an ft2232h with an proper rs485 converter to get so 12mbit. I know its over usb and pyprofibus is not realtime due to userspace, but for adding more profibus slaves baudrate cant be high enough. A real bummer would be to implement profibus to the uart of a mesa card, but my capabilities in this direction are really limited.
Time to create page: 0.186 seconds
