Linuxcnc and Profibus
4 years 2 months ago #249344 by blauerklappstuhl
Hi! I am trying to get the same setup to work.pyprofibus is running, but no communication to the cpv is possible. Perhaps my output module is faulty(no Power led). But even with only the cpv connected I cant establish connection. Dip Switches set accordingly and modules in config delted and pins # tagged. I am using an usb to rs485 connector currently. Tomorrow an serial to rs485 adapter arrived. But I thought it should work a bit with usb(maybe Just some interruptions).
@Aciera: can you help me with troubleshooting?
Alex
4 years 2 months ago #249350 by Aciera
Replied by Aciera on topic Linuxcnc and Profibus
First you will need to get the cpv module powered up. Do you have 24V on pin 1 and 0V on pin 3 of the 4-pin M12 connector?
Once you have that fixed you should launch linuxcnc from the terminal to get more debug information on what the profibus master is doing.
4 years 2 months ago - 4 years 2 months ago #249355 by blauerklappstuhl
Cpv has Power on logic and valve pin.red led is blinking once a second.
; ----------------------------------------------- ; ;                                                 ; ; PROFIBUS configuration                          ; ;                                                 ; ; This file configures a pyprofibus instance.     ; ;                                                 ; ; ----------------------------------------------- ; ; General settings [PROFIBUS] ; Enable/disable debug mode. ; 0 -> no debugging. ; 1 -> DP debugging. ; 2 -> DP and PHY debugging. debug=2 ; PHY protocol layer configuration [PHY] ; The PHY layer driver type. type=serial ; The PHY device name/path. ; Can be a device like /dev/ttyS0 or /dev/ttyAMA0 for 'serial'. dev=/dev/ttyUSB1 ; The Profibus on-wire baud rate. baud=9600 ; FDL protocol layer configuration [FDL] ; DP protocol layer configuration [DP] ; The master device class. Either 1 or 2. master_class=1 ; The Profibus address of this device. master_addr=2 ; --- ; Slave configurations ; Add as many [SLAVE_xxx] sections as needed. ; --- ; First slave configuration [SLAVE_0] ; Optional slave name. Will be stored in slaveConf.name and slaveDesc.name. ; pyprofibus does not use the name internally. name=cpv10 ; This slave's Profibus address addr=8 ; The path to the GSD file. gsd=cpv_0A35.gse ; Boolean: Sync mode enabled/available? sync_mode=1 ; Boolean: Freeze mode enabled/available? freeze_mode=1 ; 8 bit integer specifying the Profibus group ident mask. group_mask=1 ; This slave's watchdog timeout, in milliseconds. watchdog_ms=300 ; Module configuration. ; For each module plugged into the slave, add a module_xxx ; entry with the name of the module. ; The module name must match the name from the GSD file (approximately). ; The modules are used in the order of the index number. module_0=Base module:16DO ; The number of output bytes this slave transmits to the ; master in Data_Exchange. ; This usually depends on the modules plugged into the slave. output_size=2 ; The number of input bytes this slave expects to receive ; in Data_Exchange. ; This usually depends on the modules plugged into the slave. input_size=4 ; Request and interpret a slave diagnosis every n Data_Exchange telegrams. ; n defaults to 0, which means: Never periodically request diagnosis. ; If periodic diagnosis is switched off, then diagnostic information will only be requested on faults. ; Note that input-only slaves (output_size=0) probably need a non-zero diag_period. diag_period=0 [code]# --- Enable the used output pins --- # All output pins are deactivated by default. # So all output pins connected below, should be activated here by writing # a '1' to the '.active' pin. # Deactivated output pins will not be forwarded from LinuxCNC to the PROFIBUS. setp    profibus.slave.8.output.bit.0.0.active        1 setp    profibus.slave.8.output.bit.0.2.active        1 setp    profibus.slave.8.output.bit.0.4.active        1 setp    profibus.slave.8.output.bit.0.6.active        1 setp    profibus.slave.8.output.bit.1.0.active        1 setp    profibus.slave.8.output.bit.1.2.active        1 setp    profibus.slave.8.output.bit.1.4.active        1 setp    profibus.slave.8.output.bit.1.6.active        1
[/code]
cnc@cnc:~/linuxcnc/configs/BF20_MESA$ sh run-linuxcnc-demo.sh LINUXCNC - 2.8.2 Machine configuration directory is '/home/cnc/linuxcnc/configs/BF20_MESA/.' Machine configuration file is 'BF20_MESA.ini' Starting LinuxCNC... Found file(REL): ./BF20_MESA.hal Note: Using POSIX realtime hm2: loading Mesa HostMot2 driver version 0.15 hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 hm2_pci: discovered 5i25 at 0000:03:00.0 hm2/hm2_5i25.0: Low Level init 0.15 hm2/hm2_5i25.0: Smart Serial Firmware Version 43 Board hm2_5i25.0.7i76.0.0 Hardware Mode 0 = standard Board hm2_5i25.0.7i76.0.0 Software Mode 0 = io_spin Board hm2_5i25.0.7i76.0.0 Software Mode 1 = io_ana_spin Board hm2_5i25.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv hm2/hm2_5i25.0: 34 I/O Pins used: hm2/hm2_5i25.0:     IO Pin 000 (P3-01): IOPort hm2/hm2_5i25.0:     IO Pin 001 (P3-14): IOPort hm2/hm2_5i25.0:     IO Pin 002 (P3-02): IOPort hm2/hm2_5i25.0:     IO Pin 003 (P3-15): IOPort hm2/hm2_5i25.0:     IO Pin 004 (P3-03): IOPort hm2/hm2_5i25.0:     IO Pin 005 (P3-16): IOPort hm2/hm2_5i25.0:     IO Pin 006 (P3-04): IOPort hm2/hm2_5i25.0:     IO Pin 007 (P3-17): IOPort hm2/hm2_5i25.0:     IO Pin 008 (P3-05): IOPort hm2/hm2_5i25.0:     IO Pin 009 (P3-06): IOPort hm2/hm2_5i25.0:     IO Pin 010 (P3-07): Muxed Encoder Select #2, pin Mux Select 0 (Output) hm2/hm2_5i25.0:     IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input) hm2/hm2_5i25.0:     IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input) hm2/hm2_5i25.0:     IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input) hm2/hm2_5i25.0:     IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input) hm2/hm2_5i25.0:     IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input) hm2/hm2_5i25.0:     IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input) hm2/hm2_5i25.0:     IO Pin 017 (P2-01): StepGen #0, pin Direction (Output) hm2/hm2_5i25.0:     IO Pin 018 (P2-14): StepGen #0, pin Step (Output) hm2/hm2_5i25.0:     IO Pin 019 (P2-02): StepGen #1, pin Direction (Output) hm2/hm2_5i25.0:     IO Pin 020 (P2-15): StepGen #1, pin Step (Output) hm2/hm2_5i25.0:     IO Pin 021 (P2-03): StepGen #2, pin Direction (Output) hm2/hm2_5i25.0:     IO Pin 022 (P2-16): StepGen #2, pin Step (Output) hm2/hm2_5i25.0:     IO Pin 023 (P2-04): StepGen #3, pin Direction (Output) hm2/hm2_5i25.0:     IO Pin 024 (P2-17): StepGen #3, pin Step (Output) hm2/hm2_5i25.0:     IO Pin 025 (P2-05): StepGen #4, pin Direction (Output) hm2/hm2_5i25.0:     IO Pin 026 (P2-06): StepGen #4, pin Step (Output) hm2/hm2_5i25.0:     IO Pin 027 (P2-07): Smart Serial Interface #0, pin tx0 (Output) hm2/hm2_5i25.0:     IO Pin 028 (P2-08): Smart Serial Interface #0, pin rx0 (Input) hm2/hm2_5i25.0:     IO Pin 029 (P2-09): IOPort hm2/hm2_5i25.0:     IO Pin 030 (P2-10): IOPort hm2/hm2_5i25.0:     IO Pin 031 (P2-11): Muxed Encoder #0, pin Muxed Index (Input) hm2/hm2_5i25.0:     IO Pin 032 (P2-12): Muxed Encoder #0, pin Muxed B (Input) hm2/hm2_5i25.0:     IO Pin 033 (P2-13): Muxed Encoder #0, pin Muxed A (Input) hm2/hm2_5i25.0: registered hm2_5i25.0: initialized AnyIO board at 0000:03:00.0 creating ladder-state INFO CLASSICLADDER---I/O modbus master closed! inifile: warning: File contains DOS-style line endings. mb2hal parse_common_section DEBUG: [MB2HAL_INIT] [INIT_DEBUG] [3] mb2hal parse_common_section DEBUG: [MB2HAL_INIT] [HAL_MODULE_NAME] [mb2hal] mb2hal parse_common_section DEBUG: [MB2HAL_INIT] [SLOWDOWN] [0.000] mb2hal parse_common_section DEBUG: [MB2HAL_INIT] [TOTAL_TRANSACTIONS] [3] mb2hal parse_transaction_section DEBUG: [TRANSACTION_00] [LINK_TYPE] [serial] [0] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_00] [SERIAL_PORT] [/dev/RS485_FTDI] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_00] [SERIAL_BAUD] [9600] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_00] [SERIAL_BITS] [8] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_00] [SERIAL_PARITY] [none] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_00] [SERIAL_STOP] [1] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_00] [SERIAL_DELAY_MS] [6] mb2hal parse_transaction_section DEBUG: [TRANSACTION_00] [MB_SLAVE_ID] [1] mb2hal parse_transaction_section DEBUG: [TRANSACTION_00] [FIRST_ELEMENT] [8192] mb2hal parse_transaction_section DEBUG: [TRANSACTION_00] [PIN_NAMES] [command] mb2hal parse_transaction_section DEBUG: [TRANSACTION_00] [NELEMENTS] [1] mb2hal parse_transaction_section DEBUG: [TRANSACTION_00] [MAX_UPDATE_RATE] [0.000] mb2hal parse_transaction_section DEBUG: [TRANSACTION_00] [MB_RESPONSE_TIMEOUT_MS] [250] INFO CLASSICLADDER---I/O modbus master Data bits 8 Stop bits 1 Parity 0 INFO CLASSICLADDER---I/O modbus master (Serial) init ok ! mb2hal parse_transaction_section DEBUG: [TRANSACTION_00] [MB_BYTE_TIMEOUT_MS] [250] mb2hal parse_transaction_section DEBUG: [TRANSACTION_00] [DEBUG] [0] mb2hal parse_transaction_section DEBUG: [TRANSACTION_00] [MB_TX_CODE] [fnct_06_write_single_register] [4] mb2hal parse_transaction_section DEBUG: [TRANSACTION_00] [HAL_TX_NAME] [VFD_runmode] mb2hal parse_ini_file OK: parse_transaction_section 0 OK mb2hal parse_transaction_section DEBUG: [TRANSACTION_01] [LINK_TYPE] [serial] [0] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_01] [SERIAL_PORT] [/dev/RS485_FTDI] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_01] [SERIAL_BAUD] [9600] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_01] [SERIAL_BITS] [8] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_01] [SERIAL_PARITY] [none] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_01] [SERIAL_STOP] [1] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_01] [SERIAL_DELAY_MS] [6] mb2hal parse_transaction_section DEBUG: [TRANSACTION_01] [MB_SLAVE_ID] [1] mb2hal parse_transaction_section DEBUG: [TRANSACTION_01] [FIRST_ELEMENT] [4096] mb2hal parse_transaction_section DEBUG: [TRANSACTION_01] [PIN_NAMES] [frequency] mb2hal parse_transaction_section DEBUG: [TRANSACTION_01] [NELEMENTS] [1] mb2hal parse_transaction_section DEBUG: [TRANSACTION_01] [MAX_UPDATE_RATE] [0.000] mb2hal parse_transaction_section DEBUG: [TRANSACTION_01] [MB_RESPONSE_TIMEOUT_MS] [250] mb2hal parse_transaction_section DEBUG: [TRANSACTION_01] [MB_BYTE_TIMEOUT_MS] [250] mb2hal parse_transaction_section DEBUG: [TRANSACTION_01] [DEBUG] [0] mb2hal parse_transaction_section DEBUG: [TRANSACTION_01] [MB_TX_CODE] [fnct_06_write_single_register] [4] mb2hal parse_transaction_section DEBUG: [TRANSACTION_01] [HAL_TX_NAME] [VFD_write] mb2hal parse_ini_file OK: parse_transaction_section 1 OK mb2hal parse_transaction_section DEBUG: [TRANSACTION_02] [LINK_TYPE] [serial] [0] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_02] [SERIAL_PORT] [/dev/RS485_FTDI] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_02] [SERIAL_BAUD] [9600] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_02] [SERIAL_BITS] [8] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_02] [SERIAL_PARITY] [none] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_02] [SERIAL_STOP] [1] mb2hal parse_serial_subsection DEBUG: [TRANSACTION_02] [SERIAL_DELAY_MS] [6] mb2hal parse_transaction_section DEBUG: [TRANSACTION_02] [MB_SLAVE_ID] [1] mb2hal parse_transaction_section DEBUG: [TRANSACTION_02] [FIRST_ELEMENT] [4099] mb2hal parse_transaction_section DEBUG: [TRANSACTION_02] [PIN_NAMES] [voltage,ampere] mb2hal parse_transaction_section DEBUG: [TRANSACTION_02] [NELEMENTS] [2] mb2hal parse_transaction_section DEBUG: [TRANSACTION_02] [MAX_UPDATE_RATE] [0.000] mb2hal parse_transaction_section DEBUG: [TRANSACTION_02] [MB_RESPONSE_TIMEOUT_MS] [250] mb2hal parse_transaction_section DEBUG: [TRANSACTION_02] [MB_BYTE_TIMEOUT_MS] [250] mb2hal parse_transaction_section DEBUG: [TRANSACTION_02] [DEBUG] [0] mb2hal parse_transaction_section DEBUG: [TRANSACTION_02] [MB_TX_CODE] [fnct_03_read_holding_registers] [2] mb2hal parse_transaction_section DEBUG: [TRANSACTION_02] [HAL_TX_NAME] [VFD_power] mb2hal parse_ini_file OK: parse_transaction_section 2 OK mb2hal main OK: parse_ini_file done OK mb2hal init_mb_links DEBUG: LINK 0 (RTU) link_type[0] device[/dev/RS485_FTDI] baud[9600] data[8] parity[N] stop[1] fd[-1] mb2hal main OK: init_gbl.mb_link done OK mb2hal init_mb_tx DEBUG: MB_TX 0 lk_n[0] tx_n[0] cfg_dbg[0] lk_dbg[0] t_inc[0.000] nxt_t[0.000] mb2hal init_mb_tx DEBUG: MB_TX 1 lk_n[0] tx_n[1] cfg_dbg[0] lk_dbg[0] t_inc[0.000] nxt_t[0.000] mb2hal init_mb_tx DEBUG: MB_TX 2 lk_n[0] tx_n[2] cfg_dbg[0] lk_dbg[0] t_inc[0.000] nxt_t[0.000] mb2hal main OK: init_gbl.mb_tx done OK mb2hal create_each_mb_tx_hal_pins DEBUG: mb_tx_num [0] pin_name [mb2hal.VFD_runmode.num_errors] mb2hal create_each_mb_tx_hal_pins DEBUG: mb_tx_num [0] pin_name [mb2hal.VFD_runmode.command] mb2hal create_each_mb_tx_hal_pins DEBUG: mb_tx_num [1] pin_name [mb2hal.VFD_write.num_errors] mb2hal create_each_mb_tx_hal_pins DEBUG: mb_tx_num [1] pin_name [mb2hal.VFD_write.frequency] mb2hal create_each_mb_tx_hal_pins DEBUG: mb_tx_num [2] pin_name [mb2hal.VFD_power.num_errors] mb2hal create_each_mb_tx_hal_pins DEBUG: mb_tx_num [2] pin_name [mb2hal.VFD_power.voltage] mb2hal create_each_mb_tx_hal_pins DEBUG: mb_tx_num [2] pin_name [mb2hal.VFD_power.ampere] mb2hal main OK: HAL components created OK mb2hal main OK: Link thread loop and logic 0 created OK mb2hal main OK: mb2hal is running Found file(REL): ./profibus.hal GSD parser warning in 'cpv_0A35.gse' at line 14: FMS_supp            = 0  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 63: Unit_Diag_Bit(8)    = "CPI-connection to output modul"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 64: Unit_Diag_Bit(9)    = "CPI-connection to input modul"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 65: Unit_Diag_Bit(10)   = "short circuit / overload output"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 66: Unit_Diag_Bit(11)   = "power load failure output module"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 67: Unit_Diag_Bit(12)   = "sensor power supply < 10V"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 68: Unit_Diag_Bit(13)   = "valve power supply < 20.4V"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 69: Unit_Diag_Bit(14)   = "valve power supply < 10V"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 70: Unit_Diag_Bit(15)   = "no update-mode"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 71: Unit_Diag_Bit(16)   = "failure main module"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 72: Unit_Diag_Bit(17)   = "failure 1. CP- module"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 73: Unit_Diag_Bit(18)   = "failure 2. CP- module"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 74: Unit_Diag_Bit(19)   = "failure 3. CP- module"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 75: Unit_Diag_Bit(20)   = "failure 4. CP- module"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 95: Bit(1) 1 0-1  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 100: Bit(7) 1 0-1  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 105: BitArea(0-1) 0 0-2  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 110: unsigned8 0 0-255  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 114: unsigned16 0 0-65535  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 118: unsigned32 0 0-16777215  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 122: unsigned32 0 0-4294967295  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 126: unsigned8 91 0-255  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 132: Info_Text = "Base unit CPV-SC with 16 digital outputs (valve coils)"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 133: 1  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 143: Info_Text = "String extension with 8 digital outputs"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 144: 2  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 153: Info_Text = "String extension with 16 digital outputs" (classicladder:20624): Gtk-CRITICAL **: 19:08:56.053: IA__gtk_widget_get_parent: assertion 'GTK_IS_WIDGET (widget)' failed  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 154: 3  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 163: Info_Text = "String extension with 24 digital outputs"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 164: 4  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 173: Info_Text = "String extension with 32 digital outputs"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 174: 5  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 183: Info_Text = "String extension with 8 digital inputs"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 184: 6  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 191: Info_Text = "String extension with 16 digital inputs"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 192: 7  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 199: Info_Text = "String extension with 24 digital inputs"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 200: 8  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 207: Info_Text = "String extension with 32 digital inputs"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 208: 9  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 215: Info_Text = "tool change mode with 32 inputs and 32 outputs"  --> Ignored unknown line GSD parser warning in 'cpv_0A35.gse' at line 216: 10  --> Ignored unknown line pyprofibus: DP slave 8 output: 2 bytes pyprofibus: DP slave 8 input:  4 bytes Warning in GSD 'cpv_0A35.gse': DPv1 User_Prm_Data override ignored pyprofibus: Running PROFIBUS-DP master... pyprofibus: ready. Found file(REL): ./custom.hal Found file(REL): ./chinahandrad.hal pyprofibus: Active DP slave (addr=8) pins: pyprofibus: DP slave input:   profibus.slave.8.output.bit.0.0 pyprofibus: DP slave input:   profibus.slave.8.output.bit.0.2 pyprofibus: DP slave input:   profibus.slave.8.output.bit.0.4 pyprofibus: DP slave input:   profibus.slave.8.output.bit.0.6 pyprofibus: DP slave input:   profibus.slave.8.output.bit.1.0 pyprofibus: DP slave input:   profibus.slave.8.output.bit.1.2 pyprofibus: DP slave input:   profibus.slave.8.output.bit.1.4 pyprofibus: DP slave input:   profibus.slave.8.output.bit.1.6 pyprofibus: HAL configuration done DPM1: Trying to initialize slave 8... PHY-serial: TX   10 08 02 49 53 16 PHY-serial: RX   10 02 08 00 0A 16 DPM1: slave[08].state --> 'wait for diag' DPM1: Requesting Slave_Diag from slave 8... PHY-serial: TX   68 05 05 68 88 82 6D 3C 3E F1 16 PHY-serial: RX   68 0B 0B 68 82 88 08 3E 3C 02 05 00 FF 00 C9 5B 16 DPM1: slave[08].state --> 'wait for Prm' DPM1: Sending Set_Prm to slave 8... PHY-serial: TX   68 13 13 68 88 82 5D 3D 3E B8 1E 01 00 0A 35 01 00 00 00 82 00 00 00 7B 16 PHY-serial: RX   10 02 08 02 0C 16 [qtpyvcp][INFO]  Logging to /home/cnc/qtpyvcp.log (logger.py:97) [qtpyvcp][INFO]  QtPyVCP Version: v0.3.19 (opt_parser.py:199) PHY-serial: TX   68 13 13 68 88 82 7D 3D 3E B8 1E 01 00 0A 35 01 00 00 00 82 00 00 00 9B 16 PHY-serial: RX   10 02 08 02 0C 16 DPM1: State machine timeout! Trying to re-initializing slave 8... DPM1: Trying to initialize slave 8... PHY-serial: TX   10 08 02 49 53 16 PHY-serial: RX   10 02 08 00 0A 16 DPM1: slave[08].state --> 'wait for diag' DPM1: Requesting Slave_Diag from slave 8... PHY-serial: TX   68 05 05 68 88 82 7D 3C 3E 01 16 PHY-serial: RX   68 0B 0B 68 82 88 08 3E 3C 02 05 00 FF 00 C9 5B 16 DPM1: slave[08].state --> 'wait for Prm' DPM1: Sending Set_Prm to slave 8... PHY-serial: TX   68 13 13 68 88 82 5D 3D 3E B8 1E 01 00 0A 35 01 00 00 00 82 00 00 00 7B 16 PHY-serial: RX   10 02 08 02 0C 16 PHY-serial: TX   68 13 13 68 88 82 7D 3D 3E B8 1E 01 00 0A 35 01 00 00 00 82 00 00 00 9B 16 PHY-serial: RX   10 02 08 02 0C 16 DPM1: State machine timeout! Trying to re-initializing slave 8... DPM1: Trying to initialize slave 8...
[code]
[/code]
Last edit: 4 years 2 months ago by blauerklappstuhl.
4 years 2 months ago - 4 years 2 months ago #249361 by Aciera
Ok, so they are talking.
I noticed that in your pyprofibus.conf you have:
Which is incorrect. Since you have only the  base module (with 16 digital out) your slave transmits 0 bytes to the master and  expects to receive only 2 bytes from the master.
So try changing the above section to this:
; The number of output bytes this slave transmits to the ; master in Data_Exchange. ; This usually depends on the modules plugged into the slave. output_size=0 ; The number of input bytes this slave expects to receive ; in Data_Exchange. ; This usually depends on the modules plugged into the slave. input_size=2
Last edit: 4 years 2 months ago by Aciera. Reason: editor mess
4 years 2 months ago #249364 by blauerklappstuhl
hi, i changed it accordingly,but still state machine timeouts:
PHY-serial: TX 10 08 03 49 54 16
PHY-serial: RX 10 03 08 00 0B 16
PHY-serial: TX 68 05 05 68 88 83 7D 3C 3E 02 16
PHY-serial: RX 68 0B 0B 68 83 88 08 3E 3C 02 05 00 FF 00 C9 5C 16
PHY-serial: TX 68 13 13 68 88 83 5D 3D 3E B8 32 01 00 0A 35 01 00 00 00 82 00 00 00 90 16
PHY-serial: RX 10 03 08 02 0D 16
PHY-serial: TX 68 13 13 68 88 83 7D 3D 3E B8 32 01 00 0A 35 01 00 00 00 82 00 00 00 B0 16
4 years 2 months ago #249365 by Aciera
Hm. Not quite sure what is going on or if it's even important but your master has changed its address from 02 in your previous post to 03.
can you attach your current pyprofibus.conf please?
Time to create page: 0.375 seconds
