PID output not zero
5 years 1 week ago #224122 by Firehunter
Replied by Firehunter on topic PID output not zero
Thanks for your suggestion, but that doesn't really solve the problem I think. I just sets the PID output to 0 while there is still a small error. The PID loop should correct the error and then go to zero.
5 years 1 week ago #224267 by Firehunter
Just did some more testing and tuning. I got a pretty nice f-error graph on all 3 axis. Up to yesterday I had only used the x-axis. It seems that all 3 axis have the 0.002mm offset/error. I tried with some I and D values, but those didn't improve anything.
I don't think this small error will cause any problems during machining, but still it looks weird. If anyone has a suggestion what might be the cause, let me know.
5 years 1 week ago #224270 by PCW
Replied by PCW on topic PID output not zero
If you have enough I term, the error will get corrected but you will have dithering.
Actually it will get corrected even with a small I term but it may take a long time...
(minutes to hours)
4 years 11 months ago #225177 by andypugh
Replied by andypugh on topic PID output not zero
Set the GUI to display commanded position instead :-)
Time to create page: 0.148 seconds
