About 5-axis configuration
- yi2580
- Thank you received: 3
03 Nov 2021 08:21 #225078
by yi2580
About 5-axis configuration was created by yi2580
Hello, I now use qtvcp to program. I want to use 5-axis to control the machine. Is there an ini configuration file for 5-axis for reference? I want to use a-axis and c-axis to drive. What is the kinematics algorithm of AC axis? Can you tell me?
Thank you very much.
- Thank you received: 4648
04 Nov 2021 22:36 #225288
Replied by andypugh on topic About 5-axis configuration
There is a sample Vismach machine in sim/axis/vismach/
See also: linuxcnc.org/docs/2.8/html/motion/5-axis-kinematics.html
The following user(s) said Thank You: yi2580
- yi2580
05 Nov 2021 05:51 #225358
by yi2580
Replied by yi2580 on topic About 5-axis configuration
OK, thank you very much. I will refer to the example to complete it
Time to create page: 0.157 seconds
