Orient tuning, no spindle lock/brake
- Michael
- Thank you received: 59
09 Nov 2021 12:44 - 09 Nov 2021 12:48 #225863
by Michael
Orient tuning, no spindle lock/brake was created by Michael
Trying to finalize the orient with M19 and have everything really close. Currently when I orient the spindle will hold in a range of 3 encoder counts (+-.18 degrees) Spindle has a 500 quadrature encoder so its 2000ppr with an index. This accuracy is sufficient enough to trigger the default value for "orient.is-oriented". This disables the orient component and the spindle enable is shut off.
When this happens the spindle "kicks" slightly once power is released. 1 out of 10 times this "kick" is as much as 10 or more encoder counts or almost 2 degrees. Since there is no mechanical spindle brake or lock to hold it in place the orient is very inconsistent.
I have been up and down the tuning of the pid and can't get rid of the last little flutter that causes this kick when power is released. Any ideas?
Current tuning:
Current tuning:
P = 5100.0
I = 300.0
D = 85.0
FF0 = 0.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 800.0
Last edit: 09 Nov 2021 12:48 by Michael.
- Thank you received: 5337
09 Nov 2021 13:14 #225864
Replied by PCW on topic Orient tuning, no spindle lock/brake
Does it still "kick" if you disable the PID when orient is complete?
- Michael
09 Nov 2021 13:32 - 09 Nov 2021 13:33 #225865
by Michael
Replied by Michael on topic Orient tuning, no spindle lock/brake
net spindle-in-pos <= orient.is-oriented
net spindle-in-pos => spindle.0.is-oriented
This clears the original enable and moves out of M19. This is when it kicks. Is there a better way to do it? Any ideas on how to get it to settle on the final encoder count, deadband didn't work.
Last edit: 09 Nov 2021 13:33 by Michael.
- Thank you received: 4656
09 Nov 2021 13:45 #225866
Replied by andypugh on topic Orient tuning, no spindle lock/brake
As an alternative to what PCW suggested, perhaps the answer is to leave the PID enabled.
In either case, I think we need to look at the pid enable logic.
- Michael
09 Nov 2021 14:00 #225869
by Michael
I was tossing around the idea of keeping the PID on to hold the spindle till the tool change was complete. I may have over thought it however. What I came up with was a second orient component that would be activated by:
net orient-brake-enable spindle.0.locked => orient.brake.enable
and then use the same PID loop and would be cleared at the end of the toolchange.ngc with an M5
09 Nov 2021 17:34 #225896
You can probably just enable the PID with an or2 component on the current pin (spindle.0.orient?) and spindle.0.locked
- Michael
09 Nov 2021 17:59 - 09 Nov 2021 18:52 #225899
by Michael
I see what you are getting at. Very much simpler then the way I had been thinking. Will that work even though the orient.enable gets shut off?
I did go go through with making a secondary orient component to hold the spindle for the duration of the tool change. In the process of doing so I realized what may be causing some of my issue. I have a bunch of stuff out of order.
net spindle-output mux2.0.out => hm2_7i92.0.7i77.0.1.analogout5
Is at the top with orient pid below it. The orient-pid.output is above the actual orient-pid and a bunch of other stuff. Does this cause the PID calculations to be off since it will have to go through a couple servo threads to read/write values? I noticed that when I added the second orient comp that my pid tuning was way off. The second component was hacked even more then the first one.
Update: I tried to or2 the spindle.0.orient and spindle.0.locked to the orient-pid.enable but that didn't prevent the kick. It also did not cause the spindle to hold position. Just completed orientation with spindle.0.lock on
Last edit: 09 Nov 2021 18:52 by Michael.
09 Nov 2021 18:56 #225900
The order of the net statements is not important, but the order of the addf's is critical
to avoid pipeline delays. Any PID input processing components should be addf'ed
before the PID component, and any PID output processing components, should be addf'ed
after the PID component (but before the hm2_xxx write)
The following user(s) said Thank You: Michael
- Michael
09 Nov 2021 19:27 #225904
by Michael
So then:
addf orient should be above
addf orient-pid.do-pid-calcs
- Michael
09 Nov 2021 20:31 - 09 Nov 2021 20:40 #225912
by Michael
Thank you.
I got this working. And was able to create an electronic brake for the spindle through the single orient component. I was not able to get rid of the kick that happened when the orient-pid disabled or remove the couple encoder count wiggle that is present on the position loop. These are my pid settings:
Anything higher than that and the problem would only get worse. Any reason why it can't hold dead on at the index? Here is the relevant section of hal to create the electric spindle break. In a nut shell spindle.o.orient and spindle.0.locked will both enable the entire orient component. The first one starts the sequence and the next one holds the spindle after orient is complete. The toolchange.ngc will clear the whole sequence with an M5 at the end. It will also spin the spindle for half a second the first time a tool change is requested to get the spindle-index-enable correct.
Hal snip:
P = 6000
I = 300
D = 90
FF0 = 0
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 800Anything higher than that and the problem would only get worse. Any reason why it can't hold dead on at the index? Here is the relevant section of hal to create the electric spindle break. In a nut shell spindle.o.orient and spindle.0.locked will both enable the entire orient component. The first one starts the sequence and the next one holds the spindle after orient is complete. The toolchange.ngc will clear the whole sequence with an M5 at the end. It will also spin the spindle for half a second the first time a tool change is requested to get the spindle-index-enable correct.
Hal snip:
# M19 trigger orient.enable; orient-pid enable; spinena; select analogout
net spindle-orient <= spindle.0.orient
net spindle-orient => or2.1.in0 #to orient enable
net spindle-orient => and2.0.in0 #to spindle is oriented
net orient-lock <= spindle.0.locked
net orient-lock => or2.1.in1 #to orient ennable
net orient-enable <= or2.1.out
net orient-enable => orient.enable
net orient-enable => orient-pid.enable
net orient-enable => or2.0.in1 #to spindle enable
net orient-enable => mux2.0.sel
# M19 orient angle R in to orient component
net orient-angle spindle.0.orient-angle => orient.angle
# M19 orient mode P in to orient component default 0
net orient-mode spindle.0.orient-mode => orient.mode
setp orient-pid.Pgain [TUNE]P
setp orient-pid.Igain [TUNE]I
setp orient-pid.Dgain [TUNE]D
setp orient-pid.bias [TUNE]BIAS
setp orient-pid.FF0 [TUNE]FF0
setp orient-pid.FF1 [TUNE]FF1
setp orient-pid.FF2 [TUNE]FF2
setp orient-pid.deadband [TUNE]DEADBAND
setp orient-pid.maxoutput [TUNE]MAX_OUTPUT
setp orient-pid.error-previous-target true
setp orient.tolerance 0.36
# Encoder position into orient component and orient pid
net spindle-revs => orient.position
net spindle-revs => orient-pid.feedback
# Orient component position into orient pid
net orient-command orient.command => orient-pid.command
# Orient pid output to spindle analog
net spindle-orient-output orient-pid.output => mux2.0.in1
# Orient component return that orient is complete
net orient-complete <= orient.is-oriented
net orient-complete => and2.0.in1
net spindle-is-oriented <= and2.0.out
net spindle-is-oriented => spindle.0.is-oriented
# spindle output is based on mux2 and sel bit
net spindle-vel-output => mux2.0.in0
# spindle enable from or2; either spindle-vel-enable or orient-enable
net spindle-vel-enable => or2.0.in0
net spindle-enable or2.0.out => hm2_7i92.0.7i77.0.1.spinena
Last edit: 09 Nov 2021 20:40 by Michael.
Time to create page: 0.133 seconds
