C Axis question
- MaxEkb77
- Thank you received: 9
11 Nov 2021 13:17 #226131
by MaxEkb77
C Axis question was created by MaxEkb77
Hello All.
I have 4tx axis (C axis), i need run him in continuous rotation as lathe.
i created 2nd spindle an coonect him stepgen.command-vel
ok just fine.
When i try switch back to C axis, linuxcnc trying move to back position (joint.5.pos-cmd) and i got following error.
What's a correct way ?
p.s. i use a mesa card.
ok just fine.
- Thank you received: 4658
17 Nov 2021 18:03 #226812
Replied by andypugh on topic C Axis question
Look at the "orient" HAL component as a way to subtract complete turns from the commanded position.
The following user(s) said Thank You: MaxEkb77
- MaxEkb77
21 Nov 2021 20:11 #227264
by MaxEkb77
Replied by MaxEkb77 on topic C Axis question
thank you, I need full working 4 axis a turn\mill lathe.
I try to use switch kinematics.
Time to create page: 0.289 seconds
