usinf identical JoyStick hardware boards and loadusr
- ikkuh
- Thank you received: 48
Lots of troubles to get them both working at the same time. Documentation mentions that when two devices have the same name adding a :0 or :1 would make them work.
But I can't get it to work at all. There is always just one pins.input.0 I expected that there would be another as pins.input.1
hal file
loadusr -W hal_input -KRAL 14.0-1.2:0 -n Dragon:0 -d
loadusr -W hal_input -KRAL 14.0-1.3.1:1 -n Dragon:1 -d
LinuxCNC startup messagenote: name is 'DragonRise Inc. Generic USB Joystick '
[QTvcp][INFO] postgui commands: None (qtvcp:399)
[QTvcp][INFO] Preference path: /home/cnc/linuxcnc/configs/qt/qtdragon.pref (qtvcp:378)
HAL: ERROR: duplicate component name 'hal_input'
File "/usr/bin/hal_input", line 215, in <module>
h = component("hal_input")
hal.error: Invalid argument
less /proc/bus/input/devicesI: Bus=0003 Vendor=0079 Product=0006 Version=0110
N: Name="DragonRise Inc. Generic USB Joystick "
P: Phys=usb-0000:00:14.0-1.2/input0
S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:0079:0006.000D/input/input26
U: Uniq=
H: Handlers=event13 js0
B: PROP=0
B: EV=20001b
B: KEY=fff00000000 0 0 0 0
B: ABS=3002f
B: MSC=10
B: FF=107030000 0
P: Phys=usb-0000:00:14.0-1.3.1/input0
S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3/1-1.3.1/1-1.3.1:1.0/0003:0079:0006.000E/input/input27
U: Uniq=
H: Handlers=event14 js1
B: PROP=0
B: EV=20001b
B: ABS=3002f
B: MSC=10
B: FF=107030000 0
linuxcnc.org/docs/html/man/man1/hal_inpu...NPUT%20SPECIFICATION
When several devices are identified by the same string, add ":N" where N is the index of the desired device. For example, if Mouse matches input3 and input10, then Mouse and Mouse:0 select input3. Specifying mouse:1 selects input10.
Another attempt:
hal fileloadusr -W hal_input -KRAL -n Dragon:0 -d
loadusr -W hal_input -KRAL -n Dragon:1 -d
LinuxCNC startup messagesnote: name is 'DragonRise Inc. Generic USB Joystick '
buttons.hal:8: Pin 'input.0.btn-thumb2' does not exist
- Thank you received: 4656
If hal_input supports multiple joysticks (and it might) then you would need to specify both in the same loadusr command. Something like:
loadusr -W hal_input -KRAL -n Dragon:0 -n Dragon:1 -d
It might take some experimentation to see what works.
- ikkuh
Thanks, but as soon as I use the -n and name the component the pins.input.0 disapears. As soon as I remove the -n the pins show up again (for a single instance of the component).You can only "loadusr" the component once.
Maybe the joystick thingy doesn't support two or more joysticks.
- ikkuh
master/src/hal/user_comps/hal_input.py
fds = [dev.device.fileno() for dev in d]
try:
while 1:
select.select(fds, , , .01)
for i in d:
i.update()
w.drive()
I can't really test, as I don't have even one joypad.
Can you follow the logic of the argument parsing well enough to add some "print" statements to see what it is seeing?
- ikkuh
Been trying to find out what is happening and why the multiple cards can not be selected. Kinda debugging with print statements I guess. Spend already a lot of time on this, have to do some proper work now. If I find out anything I will post it here.I am not clear if you need one, two or zero -n commands.
The cards are very cheap, I paid 10 euro's for 15 inputs. www.amazon.com/s?k=arcade+usb+encoder&sp...cade+usb%2Caps%2C243
Nice cheap way to add hardware buttons to a LinuxCNC installation.
