rotary table
30 Sep 2010 21:51 #4454
by billykid
rotary table was created by billykid
Hello everyone
I'm doing the first tests with the turntable A axis, 360 degrees around.
when I turn the table in manual the screen displays a large circle that goes out the 'work area.
There are other settings to do?
thanks in advance
Mauro
thanks in advance
Mauro
02 Oct 2010 12:00 #4489
by billykid
Replied by billykid on topic Re:rotary table
I must point out that the machine works well, it's just a display issue. probably a bug in axis
Regards
Mauro
Regards
Mauro
02 Oct 2010 12:53 #4491
by BigJohnT
Replied by BigJohnT on topic Re:rotary table
What version of EMC and Ubuntu are you using?
02 Oct 2010 13:01 #4492
by billykid
Ubuntu 10.4 Emc2 2.4.4
thanks
Mauro
thanks
Mauro
02 Oct 2010 14:48 #4494
by BigJohnT
Can you post your ini file attached and change the extension to .txt so it will upload...
One suggestion is something wrong with your GEOMETRY in your ini. Try commenting it out and see what it does.
02 Oct 2010 18:59 #4496
by billykid
Thanks John, this is my ini file.
However I think the problem is this:
sourceforge.net/tracker/?func=detail&aid..._id=6744&atid=106744
Mauro
Mauro
01 Nov 2010 20:48 #5011
by billykid
Hello, now the display is pretty good, except that the diameter shown is great! can someone help me?
Regards Mauro
Regards Mauro
02 Nov 2010 12:51 #5020
Replied by andypugh on topic Re:rotary table
I have never figured out how Axis displays rotary axes, but I guess it either uses the current "relative" zero or the "machine" zero positions.
Some experimentation with homing should show which.
If it uses the machine zero, then you could get it right by changing the machine limits. For example if your X axis goes from 0 to 200 with a home position of 1, you could change the limits to -30 to 170 with a home position of -29 (as a random example). That would have no effect on anything but the Axis display (and G53 moves, if you ever do them)
Time to create page: 0.635 seconds
