Homing fails 2.9.0 pre0-5518
18 Jan 2022 10:19 #232296 by jsskangas
Homing fails 2.9.0 pre0-5518 was created by jsskangas
Hello
I updated from 2.8.0 to to current master planing to use switchkin functionality.
I updated my old setup HAL setup, only thing changed was Spindle.
Machine starts up correctly and all joint moves correctly.
If i start my own homing process it will give joint 1 following error.
Then I tested individual joints; 0,2,3 will home correctly but joint 1,4 and 5.
If I home joint 0 first this goes well, after that i try joint 1 that will give following error.
If I after this try again home joint 0 it will give error joint 1 following error.
Here is video of trying to home joint 1:
first I move it and it works as it should. This was a working setup in 2.8.0. its not a error in tuning or HAL.
then when I try to home it it will give following error.
Any idea what is wrong?
18 Jan 2022 11:29 #232302 by andypugh
Replied by andypugh on topic Homing fails 2.9.0 pre0-5518
Do the sim configs home OK?
18 Jan 2022 12:25 #232308 by jsskangas
Replied by jsskangas on topic Homing fails 2.9.0 pre0-5518
Sim config seems to home ok.
18 Jan 2022 12:30 #232309 by andypugh
Did your config ever home correctly (ie prior to 2.9-pre0-5518?)
18 Jan 2022 12:35 - 18 Jan 2022 12:41 #232310 by jsskangas
Well define correctly..
I run analog servo system with mesa card, homing use index. And has worked well last 10 years in this machine.
And during my journey with EMC2 from 2004, i only had once problem with homing.
Last edit: 18 Jan 2022 12:41 by jsskangas.
18 Jan 2022 12:43 - 18 Jan 2022 12:46 #232312 by Aciera
Replied by Aciera on topic Homing fails 2.9.0 pre0-5518
Do you mean you are using a custom homing script?
Also have you tried to increase the respective 'ferror' value and/or homing speeds of those axis in the ini file?
Last edit: 18 Jan 2022 12:46 by Aciera.
18 Jan 2022 13:46 - 18 Jan 2022 13:49 #232321 by jsskangas
Normal homing nothing special.
Homing for all joints are setup exactly same.
Example ​Joint 0 will home ok, but joint 1 will give following error.
Joints are setup correctly and if you jog them they work as they should. Can see it in youtube video.
But if you homi it it will give following error immediately.
Last edit: 18 Jan 2022 13:49 by jsskangas.
18 Jan 2022 14:02 #232326 by rodw
Replied by rodw on topic Homing fails 2.9.0 pre0-5518
V 2.9 brings with it additional homing config settings for index homing. I'm not saying they are required but please consult the homing configuration  chapter on the online docs for V 2.9
18 Jan 2022 14:33 #232333 by jsskangas
Thanks, i will look into those.
18 Jan 2022 14:41 #232334 by jsskangas
Nothing new that should affect my setup.
Time to create page: 0.447 seconds
