- Thank you received: 139
As I understand it, copy lathes do pretty well.It certainly does, but hydraulic copy mills aren't crazy high accuracy, + - 5-10 thousandths for many of them if not greater.
I think that it is easier to do it in software, but it isn't really a special velocity control mode. It's all just numbers and the controller has no idea what they really mean, that's up to you.As far as I understand there is a velocity control mode on LinuxCNC which is used to control old servos with Analog +-10V. And proportional valves also control the velocity of the Hydraulic cylinder.
So what do you think, is there a way of converting a +-10V signal into Step/Dir Pulses to let the stepper deviate from the zero position?
How is it possible to implement in software, or is it simpler to do in hardware, for example, to have an external microcontroller to convert the signals?
