Error when compiling kinematics
- LearningLinuxCNC
- Thank you received: 39
06 Apr 2022 15:36 #239472
by LearningLinuxCNC
Error when compiling kinematics was created by LearningLinuxCNC
Good day,
I am compiling a kinematics module for a custom machine that has only B axis modifications to the kinematics. I am basing the kinematics module off of maxkins.c.
when compiling using
sudo halcompile --install xyzb-kins.c
I get an error. The error is in /usr/include/linuxcnc/rtapi.h:734:5 which is included in the xyzb-kins.c file.
the error is:
error: expected ‘,’ or ‘;’ before ‘char’
char rtapi_exported_##x[] = #x;
The code in the file at this location is:
What is the correct fix for this situation?
the error is:
#define EXPORT_SYMBOL(x) __attribute__((section(".rtapi_export"))) \
#define EXPORT_SYMBOL_GPL(x) __attribute__((section(".rtapi_export"))) \
char rtapi_exported_##x[] = #x;What is the correct fix for this situation?
07 Apr 2022 17:21 #239601
Replied by andypugh on topic Error when compiling kinematics
Which kernel are you uisng? I see that section of code in rtapi.h is wrapped in some ifdef statements.
- LearningLinuxCNC
08 Apr 2022 06:31 #239651
by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Error when compiling kinematics
Andy,
uname -r returns
4.19.0-11-rt-amd64
This is installed from the 2.8.0 iso
uname -r returns
4.19.0-11-rt-amd64
09 Apr 2022 17:14 #239778
The syntax is something I am unfamiliar with, but:
gcc.gnu.org/onlinedocs/gcc/Variable-Attributes.html
suggests that attribute(( something)) is valid.
Is there any chance that you have introduced a windows-style line ending so that the continuation character is not being parsed properly?
- LearningLinuxCNC
10 Apr 2022 17:22 #239866
by LearningLinuxCNC
I don't think so. I did not actually modify this file at all. That is the same syntax and the file was downloaded directly from the linuxcnc repository. I did not change it prior to the error showing up. This is strange indeed. I will try to download the file again and replace it.
- LearningLinuxCNC
11 Apr 2022 14:34 #239961
by LearningLinuxCNC
The problem was not actually in rtapi.h
It was in the xyzb-kins.c file.
Thanks for your assistance Andy.
Compiling realtime xyzb-kins.c
xyzb-kins.c:89:1: warning: data definition has no type or storage class
KINS_NOT_SWITCHABLE
xyzb-kins.c:89:1: warning: type defaults to ‘int’ in declaration of ‘KINS_NOT_SWITCHABLE’ [-Wimplicit-int]
- LAUSCH
03 Sep 2022 03:21 #251086
by LAUSCH
Replied by LAUSCH on topic Error when compiling kinematics
Can you provide the solution to the problem? So what did you change in the code in order to make it run?
- LearningLinuxCNC
03 Sep 2022 07:32 #251102
by LearningLinuxCNC
The error in the file is that shown in the post above.
I did not need or use KINS_NOT_SWITCHABLE so this was the solution.
/*KINS_NOT_SWITCHABLE*/
The following user(s) said Thank You: LAUSCH
Time to create page: 0.149 seconds
