Spindle Coordinated motion with Mesa 7i43 & 7i33
16 Apr 2022 12:48 - 16 Apr 2022 12:54 #240409 by jatimo
Pretty sure I've just been looking at this too long and am missing something simple. Hoping someone could take a look and tell me what I might be missing.
Working on a secondary spindle on a milling machine (mounted to the table like a rotary but will be used for high speed turning). It's an AC servo with a 2500ppr quadrature encoder with index, connected to Mesa 7i43 and 7i33.  Everything is working as expected now in regard to speed control and position/speed feedback. But I can't seem to get coordinated motion to work, like G33 or M19.
I have this spindle setup as spindle $1, and in the hal file I have referred to it as "lathe" instead of "spindle" in order to disambiguate it from the primary. It's using PWM and encoder 03 on the Mesa card.
Things I have checked:
  • velocity and position feedback read as expected in halshow watch. rps/rpm/revs as expected and confirmed with laser rpm meter
  • pid.lathe.index-enable, spindle.1.index-enable and hm7i43.0.encoder.03.index-enable are connected in hal
  • hm7i43.encoder.03.input-index does trigger once as expected when rotated a full rev
  • manually setting the index-enable signal chain to true stays true until input-index is triggered.
  • input-index trigger event properly sets the index-enable signal back to false and resets spindle.1.revs to 0
  • spindle.1.at-speed is just hardwired to true for now to isolate that from the issue
    Everything appears to be working correctly at a glance but if I try to issue the following command, no axis motion takes place:
    M3 $1 S100
    G33 K0.1 X2 $1
    Also M19 does not work. No spindle motion begins and it will time out after the Q term has elapsed.
    Notably, the index-enable signal does not get set to true when G33 command is issued. spindle-orient does seem to get triggered for M19 but the cycle never goes through motion. These could be separate issues I suppose but it feels related like whatever is supposed to set index-enable is not happening and why the cycles never start.
    My hal file is below. Thanks in advance for any insight.
    note the primary spindle is driven by a separate pwm on the parport sent to a DAC, that is all working fine and can be ignored.
    loadrt [KINS]KINEMATICS
    loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_spindles=2
    loadrt hostmot2
    loadrt hm2_7i43 ioaddr=0x378 ioaddr_hi=0 epp_wide=1 config="firmware=hm2/7i43-4/SVST4_4.BIT num_encoders=4 num_pwmgens=4 num_stepgens=4"
    setp    hm2_7i43.0.pwmgen.pwm_frequency 20000
    setp    hm2_7i43.0.pwmgen.pdm_frequency 6000000
    setp    hm2_7i43.0.watchdog.timeout_ns 5000000
    loadrt hal_parport cfg="cc00 out"
    loadrt pid names=pid.x,pid.y,pid.z,pid.s,pid.lathe
    addf parport.0.read           servo-thread
    addf hm2_7i43.0.read          servo-thread
    addf motion-command-handler   servo-thread
    addf motion-controller        servo-thread
    addf pid.x.do-pid-calcs       servo-thread
    addf pid.y.do-pid-calcs       servo-thread
    addf pid.z.do-pid-calcs       servo-thread
    addf pid.s.do-pid-calcs       servo-thread
    addf pid.lathe.do-pid-calcs       servo-thread
    addf parport.0.write          servo-thread
    addf hm2_7i43.0.write         servo-thread
    # external output signals
    loadrt pwmgen output_type=0
    addf pwmgen.make-pulses servo-thread
    setp pwmgen.0.pwm-freq  2000
    setp pwmgen.0.dither-pwm 1
    setp pwmgen.0.max-dc 0.9
    setp pwmgen.0.min-dc 0.01
    net spindle-speed-cmd spindle.0.speed-out => pwmgen.0.value
    net spindle-on spindle.0.on => pwmgen.0.enable
    net spindle-pwm pwmgen.0.pwm => parport.0.pin-09-out
    # Set the spindle's top speed in RPM
    setp pwmgen.0.scale 20500
    # external input signals
    loadrt debounce cfg=4
    setp debounce.0.delay 50
    addf debounce.0 servo-thread
    net debounce-y-home-in debounce.0.1.in <= parport.0.pin-13-in-not
    net debounce-z-home-in debounce.0.2.in <= parport.0.pin-15-in-not
    net X-home  debounce.0.1.out =>  joint.0.home-sw-in  joint.1.home-sw-in
    net Z-home debounce.0.2.out =>  joint.2.home-sw-in
    net debounce-probe-in debounce.0.3.in <= parport.0.pin-12-in-not
    net probe-in debounce.0.3.out => motion.probe-input
    setp parport.0.pin-16-out 1
    #  AXIS X JOINT 0
    setp   pid.x.Pgain     [JOINT_0]P
    setp   pid.x.Igain     [JOINT_0]I
    setp   pid.x.Dgain     [JOINT_0]D
    setp   pid.x.bias      [JOINT_0]BIAS
    setp   pid.x.FF0       [JOINT_0]FF0
    setp   pid.x.FF1       [JOINT_0]FF1
    setp   pid.x.FF2       [JOINT_0]FF2
    setp   pid.x.deadband  [JOINT_0]DEADBAND
    setp   pid.x.maxoutput [JOINT_0]MAX_OUTPUT
    setp   pid.x.error-previous-target true
    net x-index-enable  <=> pid.x.index-enable
    net x-enable        =>  pid.x.enable
    net x-pos-cmd       =>  pid.x.command
    net x-pos-fb        =>  pid.x.feedback
    net x-output        <=  pid.x.output
    # ---PWM Generator signals/setup---
    setp   hm2_7i43.0.pwmgen.00.output-type 1
    setp   hm2_7i43.0.pwmgen.00.scale  [JOINT_0]OUTPUT_SCALE
    net x-output                             => hm2_7i43.0.pwmgen.00.value
    net x-pos-cmd    joint.0.motor-pos-cmd
    net x-enable     joint.0.amp-enable-out  => hm2_7i43.0.pwmgen.00.enable parport.0.pin-03-out
    setp    hm2_7i43.0.encoder.00.counter-mode 0
    setp    hm2_7i43.0.encoder.00.filter 1
    setp    hm2_7i43.0.encoder.00.index-invert 0
    setp    hm2_7i43.0.encoder.00.index-mask 0
    setp    hm2_7i43.0.encoder.00.index-mask-invert 0
    setp    hm2_7i43.0.encoder.00.scale  [JOINT_0]ENCODER_SCALE
    net x-pos-fb               <=  hm2_7i43.0.encoder.00.position
    net x-vel-fb               <=  hm2_7i43.0.encoder.00.velocity
    net x-pos-fb               =>  joint.0.motor-pos-fb
    net x-index-enable    joint.0.index-enable  <=>  hm2_7i43.0.encoder.00.index-enable
    net x-pos-rawcounts        <=  hm2_7i43.0.encoder.00.rawcounts
    # ---setup home / limit switch signals---
    net x-neg-limit     =>  joint.0.neg-lim-sw-in
    net x-pos-limit     =>  joint.0.pos-lim-sw-in
    #  AXIS Y JOINT 1
    setp   pid.y.Pgain     [JOINT_1]P
    setp   pid.y.Igain     [JOINT_1]I
    setp   pid.y.Dgain     [JOINT_1]D
    setp   pid.y.bias      [JOINT_1]BIAS
    setp   pid.y.FF0       [JOINT_1]FF0
    setp   pid.y.FF1       [JOINT_1]FF1
    setp   pid.y.FF2       [JOINT_1]FF2
    setp   pid.y.deadband  [JOINT_1]DEADBAND
    setp   pid.y.maxoutput [JOINT_1]MAX_OUTPUT
    setp   pid.y.error-previous-target true
    net y-index-enable  <=> pid.y.index-enable
    net y-enable        =>  pid.y.enable
    net y-pos-cmd       =>  pid.y.command
    net y-pos-fb        =>  pid.y.feedback
    net y-output        <=  pid.y.output
    setp   hm2_7i43.0.pwmgen.01.output-type 1
    setp   hm2_7i43.0.pwmgen.01.scale  [JOINT_1]OUTPUT_SCALE
    net y-output                             => hm2_7i43.0.pwmgen.01.value
    net y-pos-cmd    joint.1.motor-pos-cmd
    net y-enable     joint.1.amp-enable-out  => hm2_7i43.0.pwmgen.01.enable
    setp    hm2_7i43.0.encoder.01.counter-mode 0
    setp    hm2_7i43.0.encoder.01.filter 1
    setp    hm2_7i43.0.encoder.01.index-invert 0
    setp    hm2_7i43.0.encoder.01.index-mask 0
    setp    hm2_7i43.0.encoder.01.index-mask-invert 0
    setp    hm2_7i43.0.encoder.01.scale  [JOINT_1]ENCODER_SCALE
    net y-pos-fb               <=  hm2_7i43.0.encoder.01.position
    net y-vel-fb               <=  hm2_7i43.0.encoder.01.velocity
    net y-pos-fb               =>  joint.1.motor-pos-fb
    net y-index-enable    joint.1.index-enable  <=>  hm2_7i43.0.encoder.01.index-enable
    net y-pos-rawcounts        <=  hm2_7i43.0.encoder.01.rawcounts
    net y-neg-limit     =>  joint.1.neg-lim-sw-in
    net y-pos-limit     =>  joint.1.pos-lim-sw-in
    #  AXIS Z JOINT 2
    setp   pid.z.Pgain     [JOINT_2]P
    setp   pid.z.Igain     [JOINT_2]I
    setp   pid.z.Dgain     [JOINT_2]D
    setp   pid.z.bias      [JOINT_2]BIAS
    setp   pid.z.FF0       [JOINT_2]FF0
    setp   pid.z.FF1       [JOINT_2]FF1
    setp   pid.z.FF2       [JOINT_2]FF2
    setp   pid.z.deadband  [JOINT_2]DEADBAND
    setp   pid.z.maxoutput [JOINT_2]MAX_OUTPUT
    setp   pid.z.error-previous-target true
    net z-index-enable  <=> pid.z.index-enable
    net z-enable        =>  pid.z.enable
    net z-pos-cmd       =>  pid.z.command
    net z-pos-fb        =>  pid.z.feedback
    net z-output        <=  pid.z.output
    setp   hm2_7i43.0.pwmgen.02.output-type 1
    setp   hm2_7i43.0.pwmgen.02.scale  [JOINT_2]OUTPUT_SCALE
    net z-output                             => hm2_7i43.0.pwmgen.02.value
    net z-pos-cmd    joint.2.motor-pos-cmd
    net z-enable     joint.2.amp-enable-out  => hm2_7i43.0.pwmgen.02.enable
    setp    hm2_7i43.0.encoder.02.counter-mode 0
    setp    hm2_7i43.0.encoder.02.filter 1
    setp    hm2_7i43.0.encoder.02.index-invert 0
    setp    hm2_7i43.0.encoder.02.index-mask 0
    setp    hm2_7i43.0.encoder.02.index-mask-invert 0
    setp    hm2_7i43.0.encoder.02.scale  [JOINT_2]ENCODER_SCALE
    net z-pos-fb               <=  hm2_7i43.0.encoder.02.position
    net z-vel-fb               <=  hm2_7i43.0.encoder.02.velocity
    net z-pos-fb               =>  joint.2.motor-pos-fb
    net z-index-enable    joint.2.index-enable  <=>  hm2_7i43.0.encoder.02.index-enable
    net z-pos-rawcounts        <=  hm2_7i43.0.encoder.02.rawcounts
    net z-neg-limit     =>  joint.2.neg-lim-sw-in
    net z-pos-limit     =>  joint.2.pos-lim-sw-in
    # connect miscellaneous signals
    #  ---HALUI signals---
    net axis-select-x  halui.axis.x.select
    net jog-x-pos      halui.axis.x.plus
    net jog-x-neg      halui.axis.x.minus
    net jog-x-analog   halui.axis.x.analog
    net x-is-homed     halui.joint.0.is-homed
    net axis-select-y  halui.axis.y.select
    net jog-y-pos      halui.axis.y.plus
    net jog-y-neg      halui.axis.y.minus
    net jog-y-analog   halui.axis.y.analog
    net y-is-homed     halui.joint.1.is-homed
    net axis-select-z  halui.axis.z.select
    net jog-z-pos      halui.axis.z.plus
    net jog-z-neg      halui.axis.z.minus
    net jog-z-analog   halui.axis.z.analog
    net z-is-homed     halui.joint.2.is-homed
    net jog-selected-pos      halui.axis.selected.plus
    net jog-selected-neg      halui.axis.selected.minus
    net spindle-manual-cw     halui.spindle.0.forward
    net spindle-manual-ccw    halui.spindle.0.reverse
    net spindle-manual-stop   halui.spindle.0.stop
    net machine-is-on         halui.machine.is-on
    net jog-speed             halui.axis.jog-speed
    net MDI-mode              halui.mode.is-mdi
    #  ---coolant signals---
    net coolant-mist      <=  iocontrol.0.coolant-mist
    net coolant-flood     <=  iocontrol.0.coolant-flood
    #  ---probe signal---
    net probe-in     =>  motion.probe-input
    #  ---motion control signals---
    net in-position               <=  motion.in-position
    net machine-is-enabled        <=  motion.motion-enabled
    #  ---digital in / out signals---
    #  ---estop signals---
    net estop-out     <=  iocontrol.0.user-enable-out
    net estop-out     =>  iocontrol.0.emc-enable-in
    #  ---manual tool change signals---
    net tool-change-request     iocontrol.0.tool-change       =>  hal_manualtoolchange.change
    net tool-change-confirmed   iocontrol.0.tool-changed      <=  hal_manualtoolchange.changed
    net tool-number             iocontrol.0.tool-prep-number  =>  hal_manualtoolchange.number
    net tool-prepare-loopback   iocontrol.0.tool-prepare      =>  iocontrol.0.tool-prepared
    ### secondary servo spindle (lathe turn axis) on Mesa0 joint3
    setp   hm2_7i43.0.pwmgen.03.output-type 1
    setp   hm2_7i43.0.pwmgen.03.scale  [SPINDLE_1]OUTPUT_SCALE
    setp    hm2_7i43.0.encoder.03.counter-mode 0
    setp    hm2_7i43.0.encoder.03.filter 1
    setp    hm2_7i43.0.encoder.03.index-invert 0
    setp    hm2_7i43.0.encoder.03.index-mask 0
    setp    hm2_7i43.0.encoder.03.index-mask-invert 0
    setp    hm2_7i43.0.encoder.03.scale  [SPINDLE_1]ENCODER_SCALE
    setp   pid.lathe.Pgain     [SPINDLE_1]P
    setp   pid.lathe.Igain     [SPINDLE_1]I
    setp   pid.lathe.Dgain     [SPINDLE_1]D
    setp   pid.lathe.bias      [SPINDLE_1]BIAS
    setp   pid.lathe.FF0       [SPINDLE_1]FF0
    setp   pid.lathe.FF1       [SPINDLE_1]FF1
    setp   pid.lathe.FF2       [SPINDLE_1]FF2
    setp   pid.lathe.deadband  [SPINDLE_1]DEADBAND
    setp   pid.lathe.maxoutput [SPINDLE_1]MAX_OUTPUT
    setp   pid.lathe.error-previous-target true
    net lathe-revs             <=  hm2_7i43.0.encoder.03.position
    net lathe-vel-fb-rps       <=   hm2_7i43.0.encoder.03.velocity
    net lathe-vel-fb-rpm       <=   hm2_7i43.0.encoder.03.velocity-rpm
    net lathe-index-enable hm2_7i43.0.encoder.03.index-enable <=> spindle.1.index-enable
    net lathe-index-enable  <=> pid.lathe.index-enable
    net lathe-vel-cmd-rpm     => pid.lathe.command
    net lathe-vel-fb-rpm      => pid.lathe.feedback
    net lathe-enable  pid.lathe.enable => hm2_7i43.0.pwmgen.03.enable
    net lathe-output   pid.lathe.output => hm2_7i43.0.pwmgen.03.value
    net lathe-vel-cmd-rps        <=  spindle.1.speed-out-rps
    net lathe-vel-cmd-rps-abs    <=  spindle.1.speed-out-rps-abs
    net lathe-vel-cmd-rpm        <=  spindle.1.speed-out
    net lathe-vel-cmd-rpm-abs    <=  spindle.1.speed-out-abs
    net lathe-enable             <=  spindle.1.on
    net lathe-cw                 <=  spindle.1.forward
    net lathe-ccw                <=  spindle.1.reverse
    net lathe-brake              <=  spindle.1.brake
    net lathe-revs               =>  spindle.1.revs
    net lathe-at-speed           =>  spindle.1.at-speed
    net lathe-vel-fb-rps         =>  spindle.1.speed-in
Last edit: 16 Apr 2022 12:54 by jatimo.
16 Apr 2022 14:20 #240419 by jatimo
So spooled up a new configuration with PNCConf with XZ and letting it configure everything think and g33 works fine there. So I guess it's just a matter of comparing the configs now to see what I left out in my manually edited version.
18 Apr 2022 04:03 #240546 by andypugh
[*]spindle.1.at-speed is just hardwired to true for now to isolate that from the issue
I don't see that in the HAL file, but I think that if it were not true then you would be seeing other problems.
Have you got to the bottom of this? I suspect that spindle-synched motion with secondary spindles is not used very often, and as multiple spindle support is relatively new there may still be some outstanding issues.
As for M19, I don't see any sign of a position PID in the code, so I don't think that can work yet with this config.
18 Apr 2022 09:26 #240564 by jatimo
 Thanks for taking the time to look and respond.
I put a watch on the spindle.1.at-speed pin and confirmed it's staying true. I guess it defaulted to true without having been otherwise wired.
I put a watch on index-enable in the other working config (PNCConf generated) and noted the index-enable getting set by the G33 and then unset itself as it rotates past the index, then coordinated motion as expected. On my handwritten config I don't see this happening. Setting it by hand with setp/sets sets it,  and it does automatically unset itself as it rotates, but this doesn't seem to work in tricking the g33 cycle to start.
I was setting it up as secondary just to avoid having to copy over all the separate axis config and pid tuning but it makes more sense to run this as XZ anyway for turning. So in theory I have what I need now. But for the sake of other people who may need this functionality later I'll keep the proposed config to the side and try some things to narrow it down as I find time.
And oh, sorry for failing to mention, re M19 -- I had all the spindle orient stuff removed to isolate/clean up for debugging purposes. I had an or2, mux2, 2 spindles , 3 spindle pids, and and the orient component. it was getting awfully "spaghetti" in there so I removed it all to isolate one issue at a time. M19 is working OK on the generated config. From what I'm seeing I think it will work in the multi spindle config but I'll report back if I find that not to be the case.
Thanks again.
10 May 2022 11:45 #242502 by jatimo
So I got some time to look at this again. Swapped ONLY the spindle ID number in the hal config and restarted, and G33 worked fine. Renamed the original spindle to 1 and the new testing spindle as 0.
I might have made a mistake that didn't get repeated this time around. Lots of variant config files at this point trying to isolate things, and I'm a bit "punch drunk" on the issue at this point, but tried it twice and same results. So certainly not conclusive, but perhaps worth just counting as one "upvote" that there could be an issue with spindles other than #0 with coordinated motion.
Time to create page: 0.811 seconds
