Controlling hydraulic pressure feedback for chuck etc
- smc.collins
- Thank you received: 139
18 May 2022 18:43 #243306
by smc.collins
Controlling hydraulic pressure feedback for chuck etc was created by smc.collins
did some google foo here in the forum and elsewhere, I didn't find anything, so here is the question, can linux CNC control a pid to control hydraulic pressures ? IE, I might need to add or subtract clamping force from my lathe chuck, and I would like to be able to set that as either a Mcode " specify the pressure of the chuck, tailstock etc" or ladder control just generally on a per program basis to prevent operator crushing small delicate aluminum parts and housing bores. Generally it would also be nice to be able to keep pressures to a bare minimum to reduce motor loads and conserve electricity also. this unit has a single 7.5hp constant speed AC induction motor " I think I am going to control this with a VFD in the future" , so it will only consumer the current needed to maintain pressure and flow AFAICT
My machine has 3 main circuits and all of them are adjustable for pressure. would be nice to automate this, and if I did, I am thinking steppers and pressure transducers would obviously be optimal.
Thougths and feedback ?
18 May 2022 20:04 #243307
Replied by andypugh on topic Controlling hydraulic pressure feedback for chuck etc
If you have a pressure sensor and a controllable regulator then yes, a PID should do the job.
No need for anything clever like Ladder, just use M68 to drive the PID command pin directly.
- smc.collins
18 May 2022 23:27 - 19 May 2022 00:24 #243314
by smc.collins
Replied by smc.collins on topic Controlling hydraulic pressure feedback for chuck etc
I'd have to either swap out the regulator for a pwm regulator or put a motor on it to control it by turning the regulator adjustment knob
It's a down the road thing, bit I'd like to be able to do it
Last edit: 19 May 2022 00:24 by smc.collins.
19 May 2022 04:09 #243325
Yes, to control it electronically it needs to be electronically controllableI'd have to either swap out the regulator for a pwm regulator or put a motor on it to control it by turning the regulator adjustment knob
- smc.collins
19 May 2022 06:46 #243334
by smc.collins
I kinda think turning the knob,while being slower offers redundancy and simplicity in the pressure loop. Needs to be a lazy numb pid too.
19 May 2022 07:12 #243336
You need feedback of the actual pressure too. (Or, possibly a homing switch on the knob)
There is probably a Modbus / EtherCAT / serial regulator out there.
- smc.collins
19 May 2022 19:39 #243376
by smc.collins
Yeah, I was looking into analog 0-70 bar sensor, 0-4.5v, Not sure how I would implement a home switch on the knob though, I will have to measure the turns gain ratio and report back.
If you see any of the other options, please share links !
20 May 2022 14:55 #243423
Actually, with a velocity-mode stepper or a DC motor you don't need to know where the knob is, as long a the motor is strong enough to turn the knob but not to break it.
- smc.collins
20 May 2022 23:45 - 20 May 2022 23:46 #243459
by smc.collins
I would lean heavily towards a steep0er, maybe take a tq wrench once under power and measure turning tq and calculate servo/stepper demand. I don't need it to be super fast, just good enough
Last edit: 20 May 2022 23:46 by smc.collins.
Time to create page: 0.864 seconds
