PID Error Calculation
  • cprhodin
  • Topic Author
  • New Member
  • New Member
4 years 5 months ago #244351 by cprhodin
PID Error Calculation was created by cprhodin
Recently I've been tuning my system by first setting the PID coefficients to 0 and setting the FF* block to make the following error (as seen in halscope) as small as possible.  After that I tune the PID to compensate for the vagaries of the system.  When I tune this way I think there should be a one stage delay between the command input and the command/feedback adder.  The idea being that if the FF* tuning was perfect there would be no following error resulting in a zero out of the PID.  Without the delay the PID would always see an error due to acceleration.
Has anyone considered adding this delay stage?
4 years 5 months ago - 4 years 5 months ago #244419 by PCW
Replied by PCW on topic PID Error Calculation
I believe that is done by setting the error-previous-target parameter true
Last edit: 4 years 5 months ago by PCW.
  • cprhodin
  • Topic Author
  • New Member
  • New Member
4 years 4 months ago #245634 by cprhodin
Replied by cprhodin on topic PID Error Calculation
OK, I see that in the code. I was looking at the diagrams.
4 years 3 months ago #246867 by Todd Zuercher
Replied by Todd Zuercher on topic PID Error Calculation
It also helps to look at the PID-error instead of or in addition to the joint or axis f-error when tuning.
Time to create page: 0.051 seconds
