Issues Remaping M6
- LearningLinuxCNC
- Thank you received: 39
30 Jun 2022 13:52 #246293
by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Issues Remaping M6
I bet it is because it is not ran as a remap.
I will do some more testing making a simpler remap.py file and let you know what I find out.
Thanks for the feedback. It will probably be next week before I get much more done on this. Other priorities and vacation.
- Thank you received: 2181
30 Jun 2022 17:40 #246325
Replied by cmorley on topic Issues Remaping M6
have you added:
LOG_LEVEL = 1000
to the INI under [PYTHON]?
Then run from a terminal.
You may get some more info.
If it takes linuxcnc longer to load, then I would guess it's not finding the subroutines.
This looks suspicious:
SUBROUTINE_PATH = Subroutines:../../nc_files/examples/probe/basic_probe/macros/
is the nc_files folder really two levels down from your config folder? Is the examples link in the nc_files folder?
LOG_LEVEL = 1000
- LearningLinuxCNC
08 Jul 2022 15:19 #246907
by LearningLinuxCNC
Just getting back to this a week later. . .
Chris, the path is correct. It is two levels down.
linuxcnc/nc-files
linuxcnc/configs/Holloway_Sprayball_Machine
I added the LOG_LEVEL = 1000 to the python section of the .ini file. Where is this log level impacting the logging. All remains the same in the terminal window.
I am going to start with a very basic remap and see if I can make it work.
I will report back soon. I hope. Phone calls. . .
linuxcnc/nc-files
- LearningLinuxCNC
12 Jul 2022 13:59 - 12 Jul 2022 14:06 #247172
by LearningLinuxCNC
So I stripped the remap code down to just calling the stdglue change_prolog and change_epilog.
Still having the same issue. GUI is unresponsive to LinuxCNC.
I get this message
halui: emcCommandSend: no echo from Task after 5.000 seconds
If I remove everything from the remap code it works fine. The Gui works with this code.
Ok, so I uncommented the stdglue functions and now it works with this.
and it works fine.
I will keep testing. Maybe I fixed the issue unintentionally.
I get this message
def M6_Remap_sbm(self, **words):
print("M6_Remap_sbm python code running.")
# if in preview mode exit without doing anything and all ok
if self.task == 0:
return INTERP_OK
else:
return INTERP_OKOk, so I uncommented the stdglue functions and now it works with this.
if self.task == 0:
return INTERP_OK
else:
change_prolog(self, **words)
change_epilog(self, **words)
return INTERP_OKI will keep testing. Maybe I fixed the issue unintentionally.
Last edit: 12 Jul 2022 14:06 by LearningLinuxCNC. Reason: formatting of code blocks.
- LearningLinuxCNC
12 Jul 2022 14:39 #247176
by LearningLinuxCNC
All seems to be good now. I am adding my remap code back in piece by piece and things are looking good.
Not sure what the culprit line was but something in the remap code was causing a ruckus.
- CTB_le123
22 Aug 2022 22:34 - 22 Aug 2022 22:50 #250238
by CTB_le123
Replied by CTB_le123 on topic Issues Remaping M6
Hello, could you tell the github of bevins (forum.linuxcnc.org/10-advanced-configura...sons-learned?start=0) . I don't search it.
Thank you very much.
Last edit: 22 Aug 2022 22:50 by CTB_le123. Reason: I have solved it.
- LearningLinuxCNC
23 Aug 2022 09:59 #250260
by LearningLinuxCNC
Glad you solved it. I can't seem to find it now. Ha!
- CTB_le123
23 Aug 2022 19:49 #250298
by CTB_le123
Aha! Here is github.com/bobbevins/Linuxcnc_python_remap_M6.
- LearningLinuxCNC
30 Aug 2022 10:29 #250783
by LearningLinuxCNC
I have all but given up on remapping M6 with pure python. I have instead modified the stdglue change_prolog and made NGC remaps. This seems to provide what I need at the moment.
Time to create page: 0.604 seconds
