- Thank you received: 10
It is certainly part of the calculation, though I would have to experiment to see what the result is as the description in the docs is a little unclear:Not sure HOME_OFFSET works with absolute encoders.
And again your vismach model's inital joint (zero) positions need to be the same as what you had to rotate the joints to in order to derive the dh-parameters. ie if you had to rotate joint1 by 90° as in the dh-parameter documentation (due to the lack of theta
parameter in genserkins) then your model's inital position needs to have its arm pointing to the floor and not straight out.
