G76 Retract
- virencq
- Thank you received: 5
26 Aug 2022 10:37 #250525
by virencq
G76 Retract was created by virencq
I have master RIP environment along with 2.9 Linuxcnc installed.
When I run my existing configuration from RIP all working fine except encoder A and Z.
I have modified interp.convert.cc for G76 retract issue.
What I have done wrong?
30 Aug 2022 07:24 #250773
Replied by andypugh on topic G76 Retract
Can you clarify a little? For example how do you know that A and Z are not working?I have master RIP environment along with 2.9 Linuxcnc installed.
- virencq
30 Aug 2022 11:22 #250786
by virencq
Replied by virencq on topic G76 Retract
I have fully working RPI 64 bit with 2.9 Linuxcnc. Threading at 600 RPM not any issue.
I changed your perposal in G76 retract (interp.convert.cc) So I installed RIP environment master branch.
From RIP I run linuxcnc, and select my working config. and open threading g code. Now feed stops at exact G76 line.(The same code works flawlessly in installed version).
Then I checked Hal show, encoder 0,
encoder raw counts, no value on spindle rotation.
encoder velocity, no value on spindle rotation.
encoder z no signal on index slot.
Every thing working in installed .deb version
06 Sep 2022 16:35 #251357
Does an unmodified RIP version work?
Time to create page: 0.260 seconds
