I'm considering doing a LinuxCNC conversion on my Bridgeport TorqueCut 22. This machine has a somewhat unique motor drive configuration where they have digital DC servo amps which are essentially just H bridges and a small CPLD. Each axis receives a 25kHz PWM signal for control 0-100% duty cycle where 50% duty is zero current. Over 50% duty is positive current, <50% duty is negative. The CPLD maps the PWM directly into a 25khz drive waveform for the boards Hbridge. There is one of these cards per axis. If I did a conversion it would be elegant to just reuse these drivers. They work fine and are well matched to the machine's motors. Would pwmgen support this type of mapping?
I apologize if this has been asked before at some point. I searched around and didn't find another similar thread. There are a few of these machines out there that have been converted but I believe in all cases so far new analog servo amps were used, or in one case the machine was converted to all AC servo's/controllers (obviously the COOLEST approach but also the highest budget/effort).
Thank you!
James
