REMAP M6 weird issue
4 years 2 weeks ago #254258 by ddB0515
REMAP M6 weird issue was created by ddB0515
Hello all
So I have LinuxCNC 2.9 (master) on Debian 11 with probe_basic and everything works fine
As I have build rack tool changer trying to get M6 remap to work so I can do my ATC routines to be able to change tools
I have added to ini next:
[PYTHON] TOPLEVEL = ./python/toplevel.py PATH_APPEND = ./python/ PATH_APPEND = ./python/python-stdglue/ # LOG_LEVEL = 10
toplevel.py
import remap
remap.py
from stdglue import *
and python-stdglue folder copied from
/usr/share/linuxcnc/ncfiles/remap_lib
Also added to [RS274NGC]
REMAP=M6 modalgroup=6 prolog=change_prolog ngc=rack_change epilog=change_epilog
I have created simple rack_change.ngc to test if will work
o<rack_change> sub (print, Start of Program) (print, in change tool_in_spindle=#<tool_in_spindle> current_pocket=#<current_pocket>) (print, selected_tool=#<selected_tool> selected_pocket=#<selected_pocket>) ;otherwise after the M6 this information is gone! #<tool> = #<selected_tool> #<pocket> = #<selected_pocket> ;first go up G53 G0 Z0 ; then move to 1st pocket position G53 G0 X5 Y72 (print, End of Program) o<rack_change> endsub [1] M2
This is not DONE script and this is only to get it up and running but after I call M6 T2 (or any other tool) I get just this in output and my machine is not moving (so no movement on any axis)
[qtpyvcp.actions.machine_actions][INFO]  Issuing MDI command: M6 T2 (machine_actions.py:208) emcTaskPlanLevel() returned 0  Start of Program  in change tool_in_spindle=0.000000 current_pocket=0.000000  selected_tool=2.000000 selected_pocket=2.000000  End of Program emcTaskPlanExecute(M6 T2) returned 2 emcTaskPlanLevel() returned 1 emcTaskPlanSetWait() called emcTaskPlanLevel() returned 1 emcTaskPlanLevel() returned 1
So script is getting called but NO movement is done (like  G Codes are not executed), and after that I need to STOP it manually to send another command (like after that is in freezed state)
Best part is if I call for example o<go_to_home> call it works so a bit confused :(
Can anyone help with this or anyone had similar issue? I really hope someone can help me
Thanks a lot
4 years 2 weeks ago #254273 by andypugh
Replied by andypugh on topic REMAP M6 weird issue
I can understand why you would be confused. I am too.
If you type the G-code commands in the MDI window do the axes move?
I am wondering if feed hold is active or something like that. (Probably not spindle-at-speed as G0 moves don't wait for that)
It would seem logical that if you see the "End of Program" it must have finished executing the G53 G0 moves, but it might only mean that they have been added to the queue and that the interpreter has moved on.
4 years 2 weeks ago #254372 by ddB0515
Replied by ddB0515 on topic REMAP M6 weird issue
OMG
I had typo in tool-change in HAL and that's why didn't work
Fixed that and all works super fine...
net tool-prep-loop iocontrol.0.tool-prepare iocontrol.0.tool-prepared net tool-change-loop iocontrol.0.tool-change iocontrol.0.tool-changed
Note to myself: check 2x times every time HAL changes
Time to create page: 0.185 seconds
