LinuxCNC 2.9 Python module linuxcnc error
4 years 3 days ago #255373 by chili023
I want to use the compensation.py methode for autoleveling of my mill.
while loading linuxcnc the pyhton script tries to load the module linuxcnc but cannot find it.
I had to install numpy and spicy before but pip cannot find a module called linuxcnc.
Traceback (most recent call last):   File "compensation.py", line 27, in <module>     import linuxcnc ImportError: No module named linuxcnc
I assume the script is running on python 2 since I used pip and not pip3.
However python3 has a module that is named linuxcnc.
Maybe someone can point me into the right direction.
I am running LINUXCNC - 2.9.0-pre0-7877-g15792c421
File Name: compensati...10-29.py
File Size:6.86 KB
File Name: custom_202...29-2.hal
File Size:103 B
File Name: SilverGlid...29-2.hal
File Size:16.52 KB
File Name: SilverGlid...29-2.ini
File Size:5.59 KB
4 years 3 days ago #255375 by cmorley
in linuxcnc 2.9 all python programs must use python3.
Chris
4 years 3 days ago #255376 by chili023
ok how can I tell linuxcnc to use pyhton3 and not 2?
4 years 3 days ago #255377 by cmorley
how did you install linuxcnc?
4 years 3 days ago #255378 by chili023
with the package manager.
I started with the 2.8 iso and updated to 2.9.0-pre0-7877-g15792c421
4 years 3 days ago #255380 by chili023
My linuxcnc installation is using python2.
When I open python3 in the termianl and try
import linuxcnc
I get no error.
If I do that in python (2.x) <I get the error.
How can I use python3 for .py files?
Time to create page: 0.055 seconds
