Spindle Encoder Count Negative
  • COlger81
  • COlger81's Avatar Topic Author
  • Elite Member
  • Elite Member
06 Dec 2022 09:36 #258709 by COlger81
Spindle Encoder Count Negative was created by COlger81
I've been off of the mill for a while so i'm a bit rusty with LinuxCNC configs. The last issue i need to resolve is that my spindle encoder counts are counting backwards when spindle is rotating clockwise. I changed the sign for the encoder scale in the INI but it is still counting backwards. Any help is appreciated.
Chris
06 Dec 2022 10:42 - 06 Dec 2022 10:43 #258718 by scotth
Replied by scotth on topic Spindle Encoder Count Negative
Try swapping A phase and B phase on the encoder.
Last edit: 06 Dec 2022 10:43 by scotth.
The following user(s) said Thank You: COlger81
06 Dec 2022 11:15 #258721 by andypugh
Replied by andypugh on topic Spindle Encoder Count Negative
Making the scale negative really ought to have worked.
  • COlger81
  • Elite Member
  • Elite Member
06 Dec 2022 12:07 - 06 Dec 2022 12:39 #258723 by COlger81
Replied by COlger81 on topic Spindle Encoder Count Negative
I agree, but it did not. Swapping A and B phase did fix the encoder count direction but i'm seeing erratic behavior when testing rigid tap. RPM sign, position, and encoder count is reading correctly now. The index is a hall sensor directly on spindle shaft and also verified that is functioning in halshow.
VFD is a hitachi WJ200. The best i'm able to get the drive to respond to for minimum RPM is 20. Not sure if that's going to work..
If anyone has a verified reliable VFD they can suggest with linuxcnc i'm all ears. Not all that happy with this hitachi.
Last edit: 06 Dec 2022 12:39 by COlger81.
06 Dec 2022 13:01 #258726 by andypugh
I am so sure that it ought to work that I think that there is a possibility that you edited the wrong file, or that the scale is being set in more than one place.
  • COlger81
  • Elite Member
  • Elite Member
06 Dec 2022 13:21 #258728 by COlger81
Definitely edited the correct file. Where else could it be set? Oh well, swapping phases fixed that issue.
06 Dec 2022 14:07 #258735 by PCW
Replied by PCW on topic Spindle Encoder Count Negative
Its possible to have a value in an ini file that is either unused in hal or over written by a hal statement. I think this is the most likely reason changing
the scale number had no effect.
  • COlger81
  • Elite Member
  • Elite Member
06 Dec 2022 14:34 #258737 by COlger81
Any ideas on why the rigid tapping isn"t functioning properly? Encoder is counting properly and the index is functioning as it should through halshow.
  • COlger81
  • Elite Member
  • Elite Member
07 Dec 2022 14:54 #258832 by COlger81
The problem is resolved and i am now able to rigid tap.
Much appreciated!
Time to create page: 0.322 seconds
