VFD Selection for Rigid Tapping
18 Jan 2023 00:59 #262322 by msurmei
Replied by msurmei on topic VFD Selection for Rigid Tapping
Couple of questions, if I may. What kind of encoder have you used with the Marathon BlackMax motor ? Did you fit the encoder on the motor or somewere else?
18 Jan 2023 07:34 #262339 by spumco
Replied by spumco on topic VFD Selection for Rigid Tapping
The motor came with a Dynapar HS35 installed, but it was a 2048-line unit which was too high a pulse frequency (at max RPM) for my input board at the time.  Would have been fine at 1800rpm, but I was spinning the motor up to 5k.
I replaced it with a US Digital E6 that was ~400/ppr (1600 post-quad).
Encoder was motor mounted (not spindle), and the 1:1.54 belt ratio was programmed in to the control.  Index signal for rigid tapping was accomplished by mounting a small plastic ring on the top of the spindle and holding it in place with a steel set screw.  The set screw triggered a fairly high frequency proximity sensor (~7khz), which was connected to the control as the index signal.
The encoder's built-in index signal was left unconnected.
I never tried tapping at really high speeds, but I did have an 'oopsie' moment and wound up tapping a 1/4-28 hole in aluminum at ~5000rpm spindle speeds.  I crapped my pants, but the spindle & Z-axis never complained.
The following user(s) said Thank You: reddtekk, msurmei
Time to create page: 0.116 seconds
