hostmot2 oneshot bitfile help
3 years 10 months ago #259130 by PCW
Replied by PCW on topic hostmot2 oneshot bitfile help
Yes, its a simple bug fix
3 years 10 months ago #259324 by roland
Trigger1 is configured to GPIO15 in the bitfile.
I send short pulses with a frequency of about 50 Hz to the input GPIO15.
But I don't get a usable signal at pin out1. I hoped to get a signal with approx. 50 Hz and fixed width.
Is this a bug or did I configure it wrong?
3 years 10 months ago #259332 by PCW
Not sure what's going on
Did you use the latest source I attached?
Here's what I get:
3 years 10 months ago #259335 by roland
that is exactly what I expected to get
yes, i used the latest source.
LinuxCNC is the current master (buildbot). Stanza "oneshots" works now.
But I will generate the bitfile again. I want to make sure that i have indeed used the latest sources.
I will report...
3 years 10 months ago #259484 by roland
I have created the bitfile again with the latest sources. Same result.
Currently the signal comes from an optocoupler.
I use the encoder input on the 7i76 sigle ended. I checked the signal with the oscilloscope. The signal is not clean as expected.
With a short shielded cable the result was a little better. I think it is due to the electrical noise in the cabinet.
With a differential signal it would probably work reliably.
I have to find a way to get a differential signal from my laser light barrier.
3 years 10 months ago #259488 by PCW
The input digital filter should deal with most noise issues unless the are really major,
and in that casem I would expect that to show up in the unfiltered (GPIO) input as random noise pulses.
(The input filterishould normally be set to about 1/2 the expected minimum input pulse width)
Did you reload the FPGA after updating it?
Time to create page: 0.137 seconds
