help to configure spindle at speed input - Mesa 7i76
- Kasper-001
- Thank you received: 5
26 Dec 2022 15:07 #260345
by Kasper-001
help to configure spindle at speed input - Mesa 7i76 was created by Kasper-001
hey there
i need some help to setup spindle speed feedback from my vfd, it has a 0-5vdc Frequency signal output,
spindle is operative thru linuxcnc with analog speed control
d2v0huudrf11kh.cloudfront.net/vevor-cent...al_1654738270427.pdf
- Thank you received: 2181
26 Dec 2022 15:47 #260350
Replied by cmorley on topic help to configure spindle at speed input - Mesa 7i76
It also can use it's output to signal at speed.
Or do you wish to get the feedback speed regardless?
- Kasper-001
20 Jan 2023 13:47 #262521
by Kasper-001
Replied by Kasper-001 on topic help to configure spindle at speed input - Mesa 7i76
i like to use the analog output from the vfd , as signal speed
26 Jan 2023 11:36 #262945
Replied by andypugh on topic help to configure spindle at speed input - Mesa 7i76
Do you have any interface hardware that can read the 0-5V?
It might be simpler to set up Pn28 (to value 6) so that the relay output closes when the frequency is reached, and use that to trigger a digital spindle-at-speed signal.
