Remap g-code: Wait for ngc commands to complete?
- chowderhead
- Thank you received: 12
01 Feb 2023 15:35 #263467
by chowderhead
Remap g-code: Wait for ngc commands to complete? was created by chowderhead
It seems when remapping g-code, either in pure Python or using prolog/ngc/epilog, any ngc commands (either in ngc file or self.execute()) are queued and subsequent Python code is immediately executed. I need to await the conclusion of a G38 before executing subsequent code, how do I do that?
Thanks!
Thanks!
01 Feb 2023 16:05 #263470
Replied by andypugh on topic Remap g-code: Wait for ngc commands to complete?
I think that you might have almost guessed it in the title.
After a c.mdi() use a c.wait_complete()
linuxcnc.org/docs/stable/html/config/pyt...mand_code_attributes
- chowderhead
01 Feb 2023 16:20 #263473
by chowderhead
Replied by chowderhead on topic Remap g-code: Wait for ngc commands to complete?
Thank you for the quick reply!
That works for the linuxcnc python module, but I don't see wait_complete() in the interpreter module doing a print(dir(self)) from the python routine called by REMAP, so I don't think it'll work. I suppose I could import linuxcnc in remap.py and fire mdi commands, but it seems a bit kludgy...
01 Feb 2023 16:43 #263475
Can I see the code?
This might just be a consequence of how LinuxCNC works, with a realtime queue that is fed from userspace code.
Without actually setting up a remap I can't easily see what the interpreter library can do (it's not importable outside a remap, AFAIK).
Can you dir(interpreter) in your remap and look for a flush() command?
- chowderhead
01 Feb 2023 17:05 - 01 Feb 2023 17:06 #263476
by chowderhead
There is no flush in interpreter.
The following blows up with a cryptic error message:
from interpreter import *
from emccanon import MESSAGE
import hal
from time import sleep, time
throw_exceptions = 1
def M33(self, **words):
if not hal.get_value('welder.wc_ready'):
self.set_errormsg('Weld controller is not ready')
return INTERP_ERROR
if hal.get_value('welder.touch_start'):
# Enable touch sense:
touch_sense = hal.get_value('welder.touch_sense')
if touch_sense:
# Shouldn't happen
self.set_errormsg('M33 called but touch sense already enabled')
return INTERP_ERROR
else:
hal.set_p('welder.touch_sense', '1') # Value must be a string
# Wait until touch sense has been enabled
enabled = hal.get_value('welder.touch_sense_enabled')
while not enabled:
sleep(0.1)
self.execute('G90')
self.execute('G38.2 Z-10 F10')
self.execute('G91')
hal.set_p('welder.touch_sense', '0')
hal.set_p('welder.welder_on', '1')
return INTERP_OK
Last edit: 01 Feb 2023 17:06 by chowderhead.
01 Feb 2023 17:49 #263479
It's probably no help, but what is the cryptic error message?
- Thank you received: 2181
01 Feb 2023 21:25 #263490
Replied by cmorley on topic Remap g-code: Wait for ngc commands to complete?
yield INTERP_EXECUTE_FINISH
A little bit on it near the end of this section.
linuxcnc.org/docs/2.9/html/remap/remap.h...ntions_ngc_to_python
The following user(s) said Thank You: chowderhead
- chowderhead
02 Feb 2023 10:01 #263531
by chowderhead
Thank you! There is a lot on that page to digest, and I didn't see this one. I'll give it a try when I'm back in the shop.
On a related note, I'm running 2.10 on my home machine and 2.9 at the shop. They seem to yield different results with similar remaps. I'll confirm today and post the results here.
- chowderhead
03 Feb 2023 10:42 - 03 Feb 2023 10:45 #263608
by chowderhead
Thanks for the help, works a charm!
I can confirm a difference between 2.9 and 2.10. The following simple remap:
Initialized by:
Completes without issue in 2.9, but produces the following in 2.10:
def M34(self, **words):
self.execute('G91')
self.execute('G1 Z-0.1 F300')
self.execute('G90')Initialized by:
REMAP= M34 modalgroup=10 python=M34Completes without issue in 2.9, but produces the following in 2.10:
emc/task/emctask.cc 69: interp_error: remap_finished: got -13 - not in cblock.remappings!
Last edit: 03 Feb 2023 10:45 by chowderhead. Reason: Copied meta data
03 Feb 2023 12:08 #263614
Time to create page: 0.094 seconds
