Python actual_position instruction accuracy
- cnc_rocket
19 Feb 2023 13:21 #264824
by cnc_rocket
Python actual_position instruction accuracy was created by cnc_rocket
Hi there
Here is the following that I want to do:
- While my cnc is moving, I want to have a python script that spits out the position of my cnc combined with a current timestamp.
- And I want this to happen as fast as possible.
So I came up with the following idea:
I take a timestamp before I fetch the actual_position and one after, then I take the average of both.
I was wondering how accurate this is.
Could anybody give me a bit more detail in how the s.actual_position attribute works?
stamp1 = time.time()
cords = s.actual_position
stamp2 = time.time()
stamp = (stamp1 + stamp2)/2I take a timestamp before I fetch the actual_position and one after, then I take the average of both.
21 Feb 2023 07:13 #264955
Replied by andypugh on topic Python actual_position instruction accuracy
Why do you want this? Have you considered HALScope to capture the data?
- cnc_rocket
21 Feb 2023 09:02 #264959
by cnc_rocket
Replied by cnc_rocket on topic Python actual_position instruction accuracy
Thank you for your answer.
So, I have a laser sensor connected to my mill machine.
This laser sensor measures the distance to the underling surface.
I have a program where I can read out the sensor's value, with his timestamp.
Based on this timestamp, I want to match my CNC's position.
So I thought to write a python script that would spit out the CNC position and timestamp.
I didn't consider HALScope, and I don't know how I would extract that information and read that information into python.
21 Feb 2023 09:58 #264963
Generally I would avoid Python (or anything else userspace) for this sort of thing.
How does the sensor value get into the system? Can it be sampled in a realtime component and passed on to a HAL pin?
- cnc_rocket
21 Feb 2023 11:03 #264967
by cnc_rocket
No, the sensor is connected with an Ethernet cable.
The sensor sends UDP packages to the computer.
And in a packet, the time difference with the previous packet is specified.
Time to create page: 0.120 seconds
