Remap with yield INTERP_EXEC_FINISH + MDI mode
- arabel1a
- Thank you received: 4
01 Mar 2023 08:27 - 01 Mar 2023 08:30 #265655
by arabel1a
Remap with yield INTERP_EXEC_FINISH + MDI mode was created by arabel1a
Hello everyone!
I'm trying to remap M6 subroutine. Due to custom hardware usage and a lot of bash M-functions, i have to store current tool number and it's technology parameters in a file. So, my remap scheme is:
1. In prologue, read a file containing current tool, set parameters for ngc (current tool position, do it need return old tool, new tool position and etc.)
2. In ngc machine do some movements and write a new tool to a file.
Unfortunately, this does not work in auto mode. Namely, although i see that file changes, python prologue reads the prevous values. Note that in MDI everything is OK. To solve this, i've added
before reading the file and replaced all return statements with yield. This way everything works fine in auto mode, but not in MDI. If i call M6 in mdi, it prints all prints from prologue, and then frezzes, no movements nor MSG from ngc file are done.
yield INTERP_EXEC_FINISHbefore reading the file and replaced all return statements with yield. This way everything works fine in auto mode, but not in MDI. If i call M6 in mdi, it prints all prints from prologue, and then frezzes, no movements nor MSG from ngc file are done.
Last edit: 01 Mar 2023 08:30 by arabel1a.
- Thank you received: 2181
01 Mar 2023 23:48 #265696
Replied by cmorley on topic Remap with yield INTERP_EXEC_FINISH + MDI mode
I'd suggest showing you remap code, to get an chance of an opinion.
04 Mar 2023 05:41 #265837
Replied by andypugh on topic Remap with yield INTERP_EXEC_FINISH + MDI mode
I have a feeling that it might be better to work with the existing tool handling system, even if that is more difficult.
Note that iocontrol is a pluggable module, so you could use your own modified version.
linuxcnc.org/docs/stable/html/config/ini....html#_emcio_section [EMCIO]EMCIO = io / iov2 chooses between:
github.com/LinuxCNC/linuxcnc/blob/master.../iotask/ioControl.cc
and
github.com/LinuxCNC/linuxcnc/blob/master...task/ioControl_v2.cc
You can combine a modified emcio with a remap, if that is necessary.
and
Time to create page: 0.072 seconds
