Dust Collection Shoe with independent Z control
1 year 5 months ago #329307 by h_munktell
Interesting. I have just built a W, z attached dust shoe myself and started to look into getting it into HAL. Think I have almost the same requirements as you with manual override, auto-follow, park when tool changing etc. Would you mind sharing your ini file as well? And the rest of your HAL files, I'm missing the components used in your HAL above.
1 year 5 months ago - 1 year 5 months ago #329527 by h_munktell
Ok, think I have figured it out, most of it at least. Had to make a visual representation of the HAL finnstrom posted. See attachement. Also got it sort of working on my machine. Tanks so much!Some things I'll try to adopt
  • Instead of controlling with coolant-mist, I would do it with a motion.digital-out pin controlled with M62 and M63
  • Trying to get the w_offset from actual w0 in current coordinate system. My thought is to touch of both Z to the work piece, and set w0 in G54 (for example) at the desired height. Then, somehow in HAL, calculate the w0 offset from w joint zero. In the (unlikely) event that I need dust shoe for G55 etc, this should enable this to work.
  • In conjunction with above, I think I need jogging to work (in qtdragon) to easy set w0 current coordinate system.
Last edit: 1 year 5 months ago by h_munktell.
Time to create page: 0.217 seconds
