Dust Collection Shoe with independent Z control
3 years 6 months ago #269075 by andypugh
(Catching up)
Yes, my solution would leave the shoe hovering a fixed distance above the table, whilst the Z moved about. Which would be fun to watch, at least.
As you have surmised, you could use a MUX to switch that axis between W control and a fixed position. Maybe it would make sense to use the vacuum-on signal to switch the behaviour.
You don't need to re-map the M7 / M8 signals, you can just use them as-is and repurpose the HAL pins iocontrol.0.coolant-flood / coolant-mist.
You probably need a bit of extra logic so that the shoe-axis homes properly. I think I would do that by adding extra select bits to the mux.
ie
sel-0 = coolant
sel-1 = W-homing
Then connect inputs 1,2,3 to the PID and 0 to a fixed retract position.
Note that you probably want to disable the PID when it is not in use and you will have to "lie" to LinuxCNC about the W-joint position feedback to avoid following-errors. I would just short-circuit the motor-pos-cmd to motor-pos-fb and leave LinuxCNC unaware of what the shoe s doing.
2 years 11 months ago #286360 by gardenweazel
I have also created a shoe using  the W-Axis. I'd be interested in knowing how you implemented yours.
I have the W-Axis riding on my Z-Axis with printed parts that I created and a NEMA17 driving the shoe.
I can home the W-Axis without any problem but, I'm not certain of next steps other than what functionality has been mentioned
in this thread.
The one thing that is different on my setup is the W-Axis is actually mounted to the Z-Axis so it will move with the Z-Axis as well as move
up and down. My intent is to simply use an offset but, like mentioned would like to have over-ride control for tool changes, etc....
Any best practices or feedback for such implementation?
2 years 9 months ago #289695 by finnstrom
Thanks Andy.
GW:
You've got pretty much the exact same setup as me re. W on Z.
I took a long break on dust collection but am back at it and only a couple weeks from testing. I'll post my results.
The following user(s) said Thank You: gardenweazel
2 years 9 months ago #290312 by gardenweazel
I haven't tried running a job yet but, what I am going to test is as follows:
I wrote a few lines of code into my POST that simply negates the position of my Z-Axis and applied that to the W-Axis.
I included the min and max positions for my W-Axis and if the setting goes beyond those parameters
I just zeroed the W-Axis. Realistically my W-Axis should never go out of the min and max.
I'm sure that I'll need to tune it or even make changes.
2 years 9 months ago - 2 years 9 months ago #292045 by finnstrom
I did it! Man I was right at the finish line and then I fried the 7i76e joint 4 (my W axis). PCW is one of the fastest and most responsive people I've ever had the pleasure to work with, he got me back in action within days.
Just to recap, these were my goals:
  1. Get my dust shoe (that sits on its own axis (W) on top of my Z axis) to move such that it is at a fixed location with reference to the work piece.
  2. Have it retract fully when not in air/vacuum mode so that the ATC isn't blocked.
  3. Able to set the offset from Z zero (work table) on the fly in GUI
Here's what I did:
  • The first being normal W axis operation just like any other axis. This lets linuxcnc home the axis properly and myself control W independently if I ever debug or run my own slab planer code (where I actively move the dust shoe down after every pass)
  • In the second mode, I muxed the joint.4.motor-pos so that linuxcnc no longer controlled it and used instead the negative of joint.3.motor-pos together with some offsets (details below)
Simple! But with extra steps:
  1. Sum the absolute negative value of Z joint.3.pos-cmd with two offsets:
    1. The W-Z offset (zero to zero) and the Z to table offset
    2. The end work table to W offset (how high I want the shoe to hover over the work table)
  2. Limit the potential output of this to the W axis min/max, as there are no checks around this in LinuxCNC (I think the checks come earlier)
  3. Convert the absolute pos-cmd to motor-pos-cmd using motor-offset because that's what the PID uses (NOTE: I'm missing extra steps here, since generally it's not just offset, but it is for me. See joint.N.pos-cmd  here .)
  4. Mux the input so that a digital in from coolant mist activates the shoe (I'm using air and vacuum, so to be pedantic I changed the Fusion 360 post processor so that air and vacuum output M7)
  5. Mux the feedback output so that when coolant mist is active, the feedback is shorted (ie. joint.4.motor-pos-fb is connected to joint.4.motor-pos-cmd)
Caveats to this that I can think of so far:
  • I would have preferred to make Wvel just -Zvel and circumvent the W PID all together, but then I wouldn't be able to alter the W to work table offset on the fly
Thanks again Andy for pointing me in the right direction!
Hopefully this is of some help GW. Oh and I should say, the reason I didn't do the post processor method is because I am not familiar enough where I feel comfortable always keeping control of W when Z is moving. Eg. when in a drilling operation you just list Z once and then a bunch of X/Y for your holes, and LinuxCNC knows to move up/down between those operations.
# The position command is joint4 minus an offset to the surface, plus the height of the workpiece setp joint_3_following_pos_cmd_calc.gain0 1.0 setp joint_3_following_pos_cmd_calc.gain1 -1.0 setp joint_3_following_pos_cmd_calc.offset -225.0 # -(W-to-Z offset + Z-to-Table offset) net w_axis_work_offset => joint_3_following_pos_cmd_calc.in0 net joint_3_pos_cmd joint_3_following_pos_cmd_calc.in1 <= joint.3.pos-cmd net joint_3_following_pos_cmd_calc_out <= joint_3_following_pos_cmd_calc.out # Limit where joint_3_pos_cmd can go (MIN/MAX limits from ini file) setp joint_4_limit.min [JOINT_4]MIN_LIMIT setp joint_4_limit.max [JOINT_4]MAX_LIMIT net joint_3_following_pos_cmd_calc_out => joint_4_limit.in net joint_3_following_pos_cmd_calc_out_limited <= joint_4_limit.out # Convert joint_3_pos_cmd to joint_3_motor_pos_cmd setp joint_3_following_motor_pos_cmd_calc.gain0 1.0 setp joint_3_following_motor_pos_cmd_calc.gain1 1.0 net joint_3_following_pos_cmd_calc_out_limited => joint_3_following_motor_pos_cmd_calc.in0 net joint_4_motor_offset joint_3_following_motor_pos_cmd_calc.in1 <= joint.4.motor-offset net joint_3_following_motor_pos_cmd_calc_out <= joint_3_following_motor_pos_cmd_calc.out # Feed the set work offset to NGC code during shoe extend net w_axis_work_offset => motion.analog-in-00 net joint_4_motor_pos_cmd <= joint.4.motor-pos-cmd net coolant-mist => joint_4_control_mux.sel net joint_4_motor_pos_cmd => joint_4_control_mux.in0 net joint_3_following_motor_pos_cmd_calc_out => joint_4_control_mux.in1 net w-pos-cmd <= joint_4_control_mux.out net w-vel-cmd <= joint.4.vel-cmd # Only used for debugging net w-output => hm2_7i76e.0.stepgen.04.velocity-cmd # Mux the feedback. Short it if the PID is not in control. net w-pos-fb <= hm2_7i76e.0.stepgen.04.position-fb net coolant-mist => joint_4_feedback_mux.sel net w-pos-fb => joint_4_feedback_mux.in0 net joint_4_motor_pos_cmd => joint_4_feedback_mux.in1 net joint_4_motor_pos_fb joint_4_feedback_mux.out => joint.4.motor-pos-fb
Last edit: 2 years 9 months ago by finnstrom.
2 years 9 months ago #292049 by finnstrom
Ok that didn't quite work. Turns out that when I was deactivating M7 (ie. M9) I was in juuuust the right spot for motor feedback to be in the right place.
I solved this the way Andy originally suggested; I have a three states:
  1. Not homed where all works as normal
  2. Homed and shoe active (feedback off and move shoe reverse of Z with offset)
  3. Homed and shoe not active (feedback still off and move shoe to W0)
# The position command is joint4 minus an offset to the surface, plus the height of the workpiece setp joint_3_following_pos_cmd_calc.gain0 1.0 setp joint_3_following_pos_cmd_calc.gain1 -1.0 setp joint_3_following_pos_cmd_calc.offset -225.0 # -(W-to-Z offset + Z-to-Table offset) net w_axis_work_offset => joint_3_following_pos_cmd_calc.in0 net joint_3_pos_cmd joint_3_following_pos_cmd_calc.in1 <= joint.3.pos-cmd net joint_3_following_pos_cmd_calc_out <= joint_3_following_pos_cmd_calc.out # Limit where joint_3_pos_cmd can go (MIN/MAX limits from ini file) setp joint_4_limit.min [JOINT_4]MIN_LIMIT setp joint_4_limit.max [JOINT_4]MAX_LIMIT net joint_3_following_pos_cmd_calc_out => joint_4_limit.in net joint_3_following_pos_cmd_calc_out_limited <= joint_4_limit.out # Convert joint_3_pos_cmd to joint_3_motor_pos_cmd setp joint_3_following_motor_pos_cmd_calc.gain0 1.0 setp joint_3_following_motor_pos_cmd_calc.gain1 1.0 net joint_3_following_pos_cmd_calc_out_limited => joint_3_following_motor_pos_cmd_calc.in0 net joint_4_motor_offset joint_3_following_motor_pos_cmd_calc.in1 <= joint.4.motor-offset net joint_3_following_motor_pos_cmd_calc_out <= joint_3_following_motor_pos_cmd_calc.out # Feed the set work offset to NGC code during shoe extend net w_axis_work_offset => motion.analog-in-00 net joint_4_motor_pos_cmd <= joint.4.motor-pos-cmd net coolant-mist => joint_4_control_mux.sel0 net joint_4_homed joint_4_control_mux.sel1 <= joint.4.homed net joint_4_motor_pos_cmd => joint_4_control_mux.in0 # Shoe is off and we're not homed net joint_4_motor_pos_cmd => joint_4_control_mux.in1 # Shoe is on but we're not homed net joint_4_motor_offset => joint_4_control_mux.in2 # Shoe is off and we're homed, move to home (W0) net joint_3_following_motor_pos_cmd_calc_out => joint_4_control_mux.in3 # Shoe is on and we're homed net w-pos-cmd <= joint_4_control_mux.out net w-vel-cmd <= joint.4.vel-cmd # Only used for debugging net w-output => hm2_7i76e.0.stepgen.04.velocity-cmd # Mux the feedback. Short it if the PID is not in control. net w-pos-fb <= hm2_7i76e.0.stepgen.04.position-fb # Short the feedback once we're homed. net joint_4_homed => joint_4_feedback_mux.sel net w-pos-fb => joint_4_feedback_mux.in0 net joint_4_motor_pos_cmd => joint_4_feedback_mux.in1 net joint_4_motor_pos_fb joint_4_feedback_mux.out => joint.4.motor-pos-fb
The following user(s) said Thank You: h_munktell
Time to create page: 0.057 seconds
